Hytera TC-580 Microphone Replacement
  1. Hytera TC-580 Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hytera TC-580 Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hytera TC-580 Microphone Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Microphone Replacement, Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Microphone Replacement, Keypad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Microphone Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Microphone Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Microphone Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Microphone Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hytera TC-580 Microphone Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Microphone Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Microphone Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the keypad by hand.
  11. Hytera TC-580 Microphone Replacement, Speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hytera TC-580 Microphone Replacement, Speaker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hytera TC-580 Microphone Replacement, Speaker: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Microphone Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
  13. Hytera TC-580 Microphone Replacement, Microphone: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If not already done, remove the circuit board completely from the case.
  14. Hytera TC-580 Microphone Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the two microphone solder joints.
  15. Hytera TC-580 Microphone Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The microphone should fall out after all the solder has been removed.
Stuart
crwdns2935283:002/14/18crwdne2935283:0
464 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G4, Nance Spring 2018 crwdns2935289:0USF Tampa, Team S3-G4, Nance Spring 2018crwdne2935289:0
USFT-NANCE-S18S3G4
crwdns2942667:0crwdne2942667:0 940
