crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Hyppe Max Air 5000crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Hyppe Max Air 5000 Teardown, Bumper Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Bumper Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Bumper Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove rubber bumper
  2. Hyppe Max Air 5000 Teardown, Shell Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The plastic shell is ultrasonically welded shut
    • This is due to the disposable nature of the device
    • I don't have images of the removal process but I used a razor to lightly go along the seam and then spit it apart with a spudger
  3. Hyppe Max Air 5000 Teardown, Mouthpiece Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyppe Max Air 5000 Teardown, Mouthpiece Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift upwards
  4. Hyppe Max Air 5000 Teardown, Battery Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Battery Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Battery Removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the battery
    • 3.7V 1.85Wh
  5. Hyppe Max Air 5000 Teardown, Charge Port Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyppe Max Air 5000 Teardown, Charge Port Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point part of the spudger to get under the port and pry it up
  6. Hyppe Max Air 5000 Teardown, PCB screw: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyppe Max Air 5000 Teardown, PCB screw: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the PH00 screw
  7. Hyppe Max Air 5000 Teardown, Airflow sensor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Airflow sensor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Airflow sensor: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the ponty end of the spudger to lift up the airflow sensor
  8. Hyppe Max Air 5000 Teardown, Electronics Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyppe Max Air 5000 Teardown, Electronics Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use flat end of spudger to pry out chamber
    • Everything should now be come out of the plastic housing
  9. Hyppe Max Air 5000 Teardown, PCB Closeup: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyppe Max Air 5000 Teardown, PCB Closeup: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Some close up images of the PCB
  10. Hyppe Max Air 5000 Teardown, Heater Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Heater Removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Heater Removal: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull on the heater and it should just pop out
    • It's interesting to see that the heater geometry is just a mesh
  11. Hyppe Max Air 5000 Teardown, Chamber Lid Removal: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyppe Max Air 5000 Teardown, Chamber Lid Removal: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to pop off the rubber lid of the chamber
  12. Hyppe Max Air 5000 Teardown, Wicking Material: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyppe Max Air 5000 Teardown, Wicking Material: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the foam-like material
  13. Hyppe Max Air 5000 Teardown, Metal Core: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Metal Core: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hyppe Max Air 5000 Teardown, Metal Core: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use spudger to push out core
    • The heating element sits inside the sleeve. There is some wicking material on the inside to bring the nicotine liquid close to the heating mesh.
ShellingRook27
crwdns2935283:008/21/19crwdne2935283:0
2,068 crwdns2915208:0crwdne2915208:0
Repair For You crwdns2935289:0Repair For Youcrwdne2935289:0
Business
pretty cool! I recently did something similar to this when my girls vape DOA'd on her. nothing to replace failed parts with without a parts store. so i learned what you did. Still had to get her a new one. Sucks,but$20 aint that bad
dave rubio - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 3,603
