Over time, the volume wheel on the HyperX CloudX Flight may become sticky and hard to move. It may also disconnect from the interior board due to hard impacts. Use this guide to replace your volume wheel.
Gently pull around the perimeter of the left ear cup until the cushion is fully removed.
Unscrew the top of the speaker with a Phillips head screwdriver.
After taking off the top of the speaker, you will find the volume wheel wedged under the chip.
Lift the chip slightly and the volume wheel should slip right out with a bit of pressure.
