HyperX Cloud Alpha Headband Replacement
  1. HyperX Cloud Alpha Headband Replacement, Headband: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #1 screws from the clips located on the headband.
    • Repeat on the other clip. (If you did the right side first, then do the left and vice-versa.)
  2. HyperX Cloud Alpha Headband Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black plastic clips, freeing the metal sliding band inside.
  3. HyperX Cloud Alpha Headband Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Cloud Alpha Headband Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Cloud Alpha Headband Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the worn band.
crwdns2935229:05crwdne2935229:0
Shelsea Rodriguez
crwdns2935283:010/25/22crwdne2935283:0
177 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 crwdns2935289:0UMass Dartmouth, Team 5-4, Sinclaire Fall 2022crwdne2935289:0
UMASSD-SINCLAIRE-F22S5G4
¿Y qué hago con el cable que cruza dentro de la almohadilla? No puedo reemplazarlo si este está cruzado entre los dos extremos del auricular y dentro de la almohadilla misma.
Daniel Cetina Bastida - crwdns2934203:0crwdne2934203:0
This guide feels like it's missing several steps. I tried taking apart the HyperX Cloud 1 which is put together pretty much the same way. As you show in Step 2 there's a cable that runs through the headband that connects the left cup to the right cup. If your goal is to replace a worn headband, you would basically have to disconnect the cable from one of the cups which is a soldered connection, draw it out through the headband, thread it back through your replacement headband, and re-solder the cable to the cup, no? That seems like an important omission.
In my case I have no soldering skills so I opted to just cut the old headband open to get the cable free, then I put it back together with just the metal sliding band and no headband.
Terry - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 76
crwdns2936753:030crwdne2936753:0 290
crwdns2942667:0crwdne2942667:0 7,995
