HyperX Alloy Origins Key Switch Replacement
    1. HyperX Alloy Origins Key Switch Replacement, Toggle Indicator Tab: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the toggle indicator tab on the top right corner of the keyboard.
    2. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
      • Lift up gently on the tab, while holding the left side of the tab down.
      • The tab can spring upwards upon removal. Eye protection is recommended during this step.
    1. HyperX Alloy Origins Key Switch Replacement, Backplate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement, Backplate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the keyboard over so that the backplate is facing you.
    2. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the rubber feet on the four corners of the backplate.
      • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
    3. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the specified keycaps as depicted in the image.
    4. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
    5. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Separate the backplate from the keyboard using your hands.
    1. HyperX Alloy Origins Key Switch Replacement, Key Switch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement, Key Switch: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement, Key Switch: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Identify the key switch to be replaced.
      • Remove its keycap by carefully prying it off of the keyboard with your fingers.
    2. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the keyboard over to face the PCB.
      • Identify the corresponding switch to be removed.
    3. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Plug in and turn on your soldering iron.
      • Do not touch the metal end of the soldering iron while it is powered on. Allow the soldering iron to cool before stowing it away.
    4. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Key Switch Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Desoldering Pump
      $3.99
      • Melt the solder surrounding the four pins of the switch's LED, and the two lower pins of the switch body.
      • To remove the melted solder, use a desoldering iron, a desoldering pump, or desoldering braid.
      • The exposed switch pins are susceptible to damage from the soldering iron. Avoid applying heavy pressure to mitigate pin bending.
    5. HyperX Alloy Origins Key Switch Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a spudger or another metallic instrument, firmly press down upon the exposed plastic of the switch. This will separate the switch from the rest of the keyboard.
      • If the switch's pins will not separate from the keyboard's PCB, continue applying the soldering iron to the pins to melt any residual solder.
To reassemble your device, follow these instructions in reverse order. Note that when reattaching the switch back to the keyboard PCB, the switch needs to be held in place behind the keyboard while soldering.
Cameron Michaels
crwdns2935283:010/25/22crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 crwdns2935289:0UMass Dartmouth, Team 5-2, Sinclaire Fall 2022crwdne2935289:0
UMASSD-SINCLAIRE-F22S5G2
crwdns2947412:07crwdne2947412:0
Hi, I needed to replace the stabilizers for my spacebar and was able to repaire it successfully by removing the spacebar switch and using the stabilizers from the + key on the keypad which I dont care about. But now when I plug in the keyboard, there's no power at all and no input. If I didn't solder the spacebar switch back on properly, could this cause the whole keyboard to stop working? Also, I decided not to put the + switch back on since I wouldnt be using it anyway.
André Léger - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I need to replace some switches on the same keyboard and I don't know yet. where to buy it or what is the switch model or manufacturer, could you help me with that information?
Gerardo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Holaaa ando buscando un diagrama del circuito del teclado, ya que al cambiar un led una parte del teclado solo ilumina color rojo y los demas iluman en rgb :C
Francisco Alcalá - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The W key isn’t working on my sons HyperX Alloy Origins Keyboard… he’s cleaned underneath all keys for any debris and tried pressing the escape and function keys at the same time to try and reset plus tried plugging the usb into another port but W key still doesn’t work. Any other suggestions? Can you buy a replacement W key for this keyboard?
A_J - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 99
crwdns2936753:030crwdne2936753:0 485
crwdns2942667:0crwdne2942667:0 35,880
