Hydraulic Fluid Draining
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Hydraulic Fluid Draining, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hydraulic Fluid Draining, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Hydraulic Fluid Draining, Flip the engine switch to the off position: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hydraulic Fluid Draining, Flip the engine switch to the off position: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Hydraulic Fluid Draining, Close the fuel valve: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hydraulic Fluid Draining, Close the fuel valve: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the fuel valve lever to the OFF position.
  4. Hydraulic Fluid Draining, Turn off the ignition: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hydraulic Fluid Draining, Turn off the ignition: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the ignition switch to the OFF position.
    • Ensure the wheel drive control lever is set to the neutral position.
  5. Hydraulic Fluid Draining, Allow the wheels to freewheel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hydraulic Fluid Draining, Allow the wheels to freewheel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hydraulic Fluid Draining, Allow the wheels to freewheel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
    • Repeat for the left wheel.
  6. Hydraulic Fluid Draining, Add wheel chocks: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
  7. Hydraulic Fluid Draining, Remove the fill plug: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 14 mm hex key to remove the tank fill plug.
  8. Hydraulic Fluid Draining, Remove the fluid: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a siphon to pump out as much fluid as you're able to, totaling about 14 gallons.
Carsten Frauenheim
146,140 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,823crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 20
