Huawei Y300 LCD Screen Replacement
Shuti Wu
crwdns2944107:0crwdnd2944107:0Shuti Wucrwdnd2944107:0crwdnd2944107:0crwdnd2944107:010crwdnd2944107:0crwdne2944107:0
crwdns2944111:0June 26, 2024crwdne2944111:0
5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
In this guide we are going to replace the LCD display on the Huawei ascend Y300 android smartphone. This may be necessary for a damaged screen causing lines, dark spots, and distorted images. The damage may be caused by:
  • Physical impacts/pressure
  • Heat
  • Moisture
  • Dust
Before we start it is a good idea to prepare an organized area and a bowl or tray to put the small screws in and prevent them getting lost to carry out the repair.
crwdns2944105:0crwdne2944105:0
crwdns2943227:0crwdne2943227:0
  1. Huawei Y300 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Y300 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear cover at the back by pulling the gap located at the bottom of the phone.
    • Lift up and remove the battery.
  2. Huawei Y300 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Y300 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Y300 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Leave the phone down on a table.
    • 8 screws are what we need to remove next. There is one hiding below a white sticker.
  3. Huawei Y300 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Y300 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a screwdriver (T4 if you are using the 54 bit driver kit) to remove the 8 screws along the edges of the phone. There are four in each corner and four in the middle on the sides.
    • Put the screws on the magnetic mat/parts tray or bowl to make sure they are not lost.
  4. Huawei Y300 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Y300 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Y300 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool by fitting it into the gaps to pull back the frame.
  5. Huawei Y300 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Y300 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Y300 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the left of the motherboard there is a ribbon cable that connects the volume rocker to the motherboard, we need to disconnect it.
    • To do this, using either the spudger or tweezers lift up the retention flap holding the cable down.
    • Next using the tweezers carefully pull the ribbon cable away from the socket it was in until it is completely clear of the connector.
  6. Huawei Y300 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two more ribbon cables at the top that must also be disconnected, to do this simply lift them up from their connecter with the tweezers or with the spudger.
    it's important to add that lateral flat cable can be lift up only after turning up the rotating switch which is on the lower side.
    Alberto Marullo - crwdns2934203:0crwdne2934203:0
    just did some edits to this repair guide fixing that issue, the edits are just waiting to be verified, sorry about the poor image quality in the new step 6 best I could do with only 2 hands and a OnePlus One camera.
    Jack Punter -
  7. Huawei Y300 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Y300 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back the orange tab. Carefully disconnect this.
  8. Huawei Y300 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the orange tabs are pulled back, use a plastic wedge to detach the LCD screen.
    • Carefully pull the screen away from the cover and replace the LCD with a new one
crwdns2935229:044crwdne2935229:0
Shuti Wu
crwdns2935283:010/20/14crwdne2935283:0
530 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 crwdns2935289:0UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014crwdne2935289:0
UMASSD-VIJAYBHASKAR-F14S5G3
Its really helpful and so easy ... thanks
Ghulam Qamar - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 17,526
