This guide will demonstrate how to replace your watch's straps. Some of the tools used in this guide are relatively sharp, so make sure to use them with care.
Begin by laying the watch on a flat, smooth surface.
Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
Locate the two springs on the back of your watch.
Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
Carefully pull the strap away from the watch.
Repeat step 3, this time using the other strap.
