Huawei Watch Jewel Motherboard Replacement
  1. Huawei Watch Jewel Motherboard Replacement, Strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Motherboard Replacement, Strap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by laying the watch on a flat, smooth surface.
    • This will prevent the watch screen from suffering damage.
    • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
  2. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two springs on the back of your watch.
    • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
  3. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Watch Jewel Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Watch Jewel Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
  4. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the strap away from the watch.
  5. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat step 3, this time using the other strap.
  6. Huawei Watch Jewel Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
  7. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Metal Spudger to pry open the back of your watch.
    • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
  8. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back case.
  9. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
    • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
  10. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
    • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
  11. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $2.99
    • Use the Metal Spudger to lift the mother board from the watch.
    • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
  12. Huawei Watch Jewel Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
ngan tran
crwdns2935283:002/15/17crwdne2935283:0
526 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-3, Passmore Spring 2017 crwdns2935289:0USF Tampa, Team 5-3, Passmore Spring 2017crwdne2935289:0
USFT-PASSMORE-S17S5G3
where i can i buy Huawei Watch Jewel Motherboard online?
Mao Sereivathanak - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,340
