Huawei Watch Jewel Battery Replacement
  1. Huawei Watch Jewel Battery Replacement, Strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Battery Replacement, Strap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by laying the watch on a flat, smooth surface.
    • This will prevent the watch screen from suffering damage.
    • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
  2. Huawei Watch Jewel Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two springs on the back of your watch.
    • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
  3. Huawei Watch Jewel Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Watch Jewel Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Watch Jewel Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
  4. Huawei Watch Jewel Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the strap away from the watch.
  5. Huawei Watch Jewel Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat step 3, this time using the other strap.
  6. Huawei Watch Jewel Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
    I have a Huawei Watch W1 Active and the screws are smaller than the T3 Torx ones. Is the hardware of the Huawei Watches W1 different depending on the model? I’m trying to use a T3 Torx Wiha Precision ESD 278 and it is bigger than the watch holes.
    Iván Pereira - crwdns2934203:0crwdne2934203:0
    I bought a kit on ebay and followed these instructions. They were clear and SUPER helpful. THANK YOU!!! I’m so grateful I’m able to extend the life of my watch for a fraction of the cost of a new one especially since this model is discontinued.
    tyrosluver - crwdns2934203:0crwdne2934203:0
  7. Huawei Watch Jewel Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Metal Spudger to pry open the back of your watch.
    • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
  8. Huawei Watch Jewel Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back case.
  9. Huawei Watch Jewel Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch Jewel Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
    • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
  10. Huawei Watch Jewel Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
    • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
    Screws are very short so expect them to unscrew quickly. Also if the battery is old and has been swelling, the motherboard will pop up, be sure to expect that so you don't lose any screws.
    Edward Beheler - crwdns2934203:0crwdne2934203:0
  11. Huawei Watch Jewel Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $2.99
    • Use the Metal Spudger to lift the mother board from the watch.
    • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
  12. Huawei Watch Jewel Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
  13. Huawei Watch Jewel Battery Replacement, Battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Picks (Set of 6)
    • Use the spudger or opening pick to carefully lift the battery from the watch.
    • Ensure that the polarity (+/- signs) of the new battery match that of the old battery when inserting new battery into device.
    • Avoid using a metal spudger as it may cause damage to the battery or device. Use an opening pick when possible.
    Battery is glued to the watch face, so it will take some effort with a plastic spudger to release it.
crwdns2935229:020crwdne2935229:0
ngan tran
crwdns2935283:002/15/17crwdne2935283:0
510 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-3, Passmore Spring 2017 crwdns2935289:0USF Tampa, Team 5-3, Passmore Spring 2017crwdne2935289:0
USFT-PASSMORE-S17S5G3
crwdns2947412:08crwdne2947412:0
Any idea where one can purchase the actual battery? I can’t find one anywhere.
Chris Wellings - crwdns2934203:0crwdne2934203:0
@Chris wellings: i was able to find one on ebay. Arrived quite quickly. And you definitely need a T2(not 3) screwdriver to open up the watch.
edgar.dumea - crwdns2934203:0crwdne2934203:0
Also found one on eBay. I was replacing the battery on the standard Huawei Watch (W1) and this guide was really helpful.
Alex Swanson -
thanks for this great guide, it’s very clear. My W1’s battery is still OK, but I’m anticipating needing to change it sometime and your guide removes the fear!
Paul M - crwdns2934203:0crwdne2934203:0
T2, the T3 bit is definitely too big for these
Gregory Klyushnikov -
T3 fit for me
Jeff Thurston -
It is not necessary to remove the glued down connector. The motherboard can be lifted out of the way while it is still connected via that flexy. It just requires a little care.
David Smith - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 23,493
