Use this guide if your Huawei Union’s speaker will not play sound while watching videos or listening to music.
Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Remove the thirteen 3mm Phillips #00 screws from the back panel.
Use the flat end of a spudger to pry off the back panel.
Use the flat end of a spudger to lift the speaker out of the frame and remove.
