crwdns2959928:0crwdne2959928:0 ↓Use this guide if your Huawei Union will not charge when plugged into a charger or begins losing charge faster than previously observed.
Spudger4.9
Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Remove the thirteen 3mm Phillips #00 screws from the back panel.
Use the flat end of a spudger to pry off the back panel.
Remove a single 3mm Phillips #00 screw from the motherboard.
Using the flat end of a spudger to disconnect the motherboard ribbon cable.
Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
