Huawei P8 Lite Motherboard Replacement
  1. Huawei P8 Lite Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM card tray.
    • Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
  2. Huawei P8 Lite Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    • The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
  3. Huawei P8 Lite Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
    • PH000 Bit
    • T5 Torx
  4. Huawei P8 Lite Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
    • These connectors are extremely fragile, so avoid using any kind of tools and make sure to be extremely gentle in the process.
  5. Huawei P8 Lite Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard carefully.
    • Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
crwdns2935229:08crwdne2935229:0
Brayden Mann
crwdns2935283:002/05/16crwdne2935283:0
645 crwdns2915208:0crwdne2915208:0
Metro State, Team 1-2, Carpenter Spring 2016 crwdns2935289:0Metro State, Team 1-2, Carpenter Spring 2016crwdne2935289:0
MSU-CARPENTER-S16S1G2
Anywhere to buy this motherboard? Maybe display as well?
Jan Šinkovec - crwdns2934203:0crwdne2934203:0
mine also need a new mother
anywr l can get it asap
blessed - crwdns2934203:0crwdne2934203:0
Hey
I need p8 lite motherboard
goitsemodimo - crwdns2934203:0crwdne2934203:0
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
Alvaro Gomes - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,368
