In this guide, instructions will be laid out to guide the replacement of the Huawei P8 Lite's motherboard.
Before starting, please refer to the device's teardown guide to get started.
Remove the SIM card tray.
Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
Remove the back cover.
The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
PH000 Bit
T5 Torx
Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
Remove the motherboard carefully.
Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
crwdns2935229:08crwdne2935229:0
Anywhere to buy this motherboard? Maybe display as well?
mine also need a new mother
anywr l can get it asap
Hey
I need p8 lite motherboard
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
