Huawei P20 Lite Display (with frame and battery) Replacement
  1. Huawei P20 Lite  Display (with frame and battery) Replacement, Remove SIM Card Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the phone off and remove the SIM Tray before beginning the repair
  2. Huawei P20 Lite  Display (with frame and battery) Replacement, Remove Battery Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P20 Lite  Display (with frame and battery) Replacement, Remove Battery Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a suction cup and pick to get between the battery cover and frame.
    • Work the pick all the way around to loosen the adhesive and remove the cover.
    • Flip the cover carefully to the right side of the phone, there is a cable attached to the back cover for the fingerprint ID sensor.
  3. Huawei P20 Lite  Display (with frame and battery) Replacement, Release Fingerprint ID Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the ZIF connector to remove the Fingerprint scanner cable from the back cover.
  4. Huawei P20 Lite  Display (with frame and battery) Replacement, Remove Upper Screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 8 upper screws that hold the metal covers.
    • One of the screws may be covered with a white dot sticker. Remove the dot to access the screw.
  5. Huawei P20 Lite  Display (with frame and battery) Replacement, Remove covers for cables and mainboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P20 Lite  Display (with frame and battery) Replacement, Remove covers for cables and mainboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws have been removed (as described in the previous step) the two lower metal covers can be removed.
    • The upper cover can be removed by prying the upper right corner free (2nd picture).
  6. Huawei P20 Lite  Display (with frame and battery) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the left side in the frame, is a small plastic retainer. Remove this and transfer to the new frame.
  7. Huawei P20 Lite  Display (with frame and battery) Replacement, Disconnect cables: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery connector from the mainboard.
    • Remove the dual camera, the front camera and the two flex cables. The Wi-Fi antenna cable can also be disconnected
  8. Huawei P20 Lite  Display (with frame and battery) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, carefully pry the mainboard up on the upper right corner to release it from the frame.
  9. Huawei P20 Lite  Display (with frame and battery) Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At the bottom of the phone, there are seven screws that need to be removed.
    • Underneath the cover is the daughterboard
  10. Huawei P20 Lite  Display (with frame and battery) Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P20 Lite  Display (with frame and battery) Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P20 Lite  Display (with frame and battery) Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iOpener or a similar tool, loosen the cover on the right side, by prying between the cover and the frame.
    • At the top of the cover (2nd picture) use the iOpener to pry up the cover to remove it from the frame.
    • Underneath the cover is the daughter board containing the charger port and headphone jack. Disconnect the cable attached to the daughter board.
    • Pry the daughter board to remove it from the frame, it is lightly glued, and can be reused in the new frame.
    • Repeat the steps in reverse to reassemble the phone.
crwdns2935229:041crwdne2935229:0
Harvey
crwdns2935283:002/15/16crwdne2935283:0
6,189 crwdns2915208:0crwdne2915208:0
crwdns2947412:025crwdne2947412:0
Can the antenna cable (black thin one) be reused?
Edvin Mattsson - crwdns2934203:0crwdne2934203:0
Yes, all the cables that are removable can be reused.
Harvey - crwdns2934203:0crwdne2934203:0
hi, when you replace a faulty battery does the screen needs to be changed as well even though the screen is fine?
fundiswamkutyukelwa - crwdns2934203:0crwdne2934203:0
Normally if you can remove the battery, without damaging the screen then just replacing the battery should be ok
Harvey -
I had to replace the back cover as well as it was also damaged. You will have to try it and see if the adhesive is still strong enough to stick.
Harvey -
crwdns2936753:07crwdne2936753:0 79
crwdns2936753:030crwdne2936753:0 354
crwdns2942667:0crwdne2942667:0 60,046
