Huawei MateBook E 2022 SSD Upgrade/Replacement
  1. Huawei MateBook E 2022 SSD Upgrade/Replacement, Create an opening gap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up the iOpener for 30 seconds in the microwave. Then, heat up the bottom edge of the display for 90 seconds.
    • Place the iSclack in the middle of the bottom edge.
    • Press the iSclack to create a small gap between the display and the case.
    • Once you've opened a sufficient gap, insert an opening pick into the gap.
  2. Huawei MateBook E 2022 SSD Upgrade/Replacement, Slice through the bottom adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slice through the adhesive under the screen by sliding the pick along the edge of the display, towards the bottom corners.
    • Leave the pick in place temporarily to prevent the adhesive from re-sealing.
    • Heat up the other edges of the display with the iOpener and work your way through all sides.
    • The display is connected to the laptop with fragile cables. Don't insert the pick deeper than 1cm.
  3. Huawei MateBook E 2022 SSD Upgrade/Replacement, Remove the display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei MateBook E 2022 SSD Upgrade/Replacement, Remove the display: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iFixit Opening Tool
    $1.99
    • Lift the display from the right side (with the camera).
    • The display is still connected to the laptop with a cable. Don't lift it to far away from the case.
    • Remove the two PH1-screws and the bracket.
    • Disconnect the display cable with the iFixit Opening Tool.
    • Remove the entire display and put it aside.
    • Put the display on a soft surfe, so as not to scratch it.
  4. Huawei MateBook E 2022 SSD Upgrade/Replacement, Remove the frame: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei MateBook E 2022 SSD Upgrade/Replacement, Remove the frame: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 46 silver PH1-screws.
    • Remove the 4 black PH1-screws.
    • The silver screws all have the same size, you don't have to remember where each one goes. The location of the black screws is marked with an arrow.
    • Remove the middle frame. The battery is attached on the underside, the frame might be heavier than initially expected.
  5. Huawei MateBook E 2022 SSD Upgrade/Replacement, Replace SSD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the PH1-screw, mounting the M.2 SSD.
    • Remove the heat shield from the old SSD and attach it to the new SSD.
    • Install the new SSD into the laptop with the screw.
  6. Huawei MateBook E 2022 SSD Upgrade/Replacement, Remove old tape: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any residue of the old tape from the four edges of the case.
    • Remove any residue on the back side of the display.
    • The display is very fragile, don't use too much force. The black frame is printed on the backside of the display, watch out to not scratch it.
  7. Huawei MateBook E 2022 SSD Upgrade/Replacement, Attach new tape: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After mounting the middle frame, attach the new tape to the case.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0Mingkwan Burckhardtcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Mingkwan Burckhardt
crwdns2935283:007/22/22crwdne2935283:0
307 crwdns2915208:0crwdne2915208:0
crwdns2947412:09crwdne2947412:0
Which thickness should the new Tape have? 1/2/4/8mm?
Amer - crwdns2934203:0crwdne2934203:0
I used 3M 300LSE in 10mm width, but 8mm should work as well. I used a pick to get the tape fully into the edge and then trimmed the excess on both sides with a sharp knife, so the width doesn't really matter as long as its wide enough to cover the surface at the edge. Ideally, you use a precut tape if those are available.
Mingkwan Burckhardt -
What's the largest storage capacity you can put into this device?
I'm planning on upgrading mine.
Michael Johnson Bocateja - crwdns2934203:0crwdne2934203:0
It‘s a M.2 slot, so basically any 2280 NVMe will fit. The sweet spot right now seem to be 2TB or 4TB SSDs, depends on your budget of course.
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 77
crwdns2936753:030crwdne2936753:0 414
crwdns2942667:0crwdne2942667:0 13,118
