Huawei MateBook D 15 (2020) LCD Replacement
  1. Huawei MateBook D 15 (2020) LCD Replacement, Case removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei MateBook D 15 (2020) LCD Replacement, Case removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei MateBook D 15 (2020) LCD Replacement, Case removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 10 P5 screws securing the case.
    • Use a spudger to pry the edges of the case up, releasing the plastic tabs holding the base in place.
  2. Huawei MateBook D 15 (2020) LCD Replacement, Battery removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei MateBook D 15 (2020) LCD Replacement, Battery removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 PH00 screws holding the battery in place.
    • Slide the battery forwards and lift it from its housing.
    • Do NOT remove the battery yet, as it is still connected to the motherboard.
    • Pry the end of the battery connector from its housing.
    • Remove the battery.
    • When reassembling, remember that replacing the battery cable in its housing requires a sliding motion in the direction of the motherboard.
  3. Huawei MateBook D 15 (2020) LCD Replacement, Remove bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei MateBook D 15 (2020) LCD Replacement, Remove bezel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger or pry tool, separate the screen bezel from the case.
    • The bezel is made from thin plastic that should not have too much force exerted on it. Exercise caution during this step.
    • Separate the bezel from the hinge housing and remove it.
  4. Huawei MateBook D 15 (2020) LCD Replacement, Break LCD adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei MateBook D 15 (2020) LCD Replacement, Break LCD adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a pry tool onto either side of the LCD and slide downwards towards the keyboard.
    • Repeat for the opposite side once all adhesive is broken. There are no delicate cables between this LCD and the top of the laptop case.
    • Fold the LCD upwards towards the keyboard.
  5. Huawei MateBook D 15 (2020) LCD Replacement, Remove the LCD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei MateBook D 15 (2020) LCD Replacement, Remove the LCD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the piece of tape holding the LCD cable in place
    • The LCD cable has two delicate outcroppings on each side which should not be used to pull the cable backwards.
    • Pull the cable away, removing it from the LCD.
    • Remove the LCD.
    • Follow these steps in reverse order to reassemble.
Pig PlayzMC
crwdns2935283:002/24/20crwdne2935283:0
44 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 104
crwdns2936753:030crwdne2936753:0 169
crwdns2942667:0crwdne2942667:0 169
