This guide show the process of back panel replacement on the Huawei M750.
Depress the top of the battery cover, and pull downwards towards the base of the phone.
Remove the battery by levering the battery out, using the cut just below the camera.
Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
Work the opening tool around the border of the camera and speaker cover, until it comes loose.
Using the T5 Torx screwdriver, remove the six 6mm screws.
Using the opening tool, pry the back panel from the front panel.
Work your way around the phone until the panels separate evenly.
