Huawei Honor 8 Battery Replacement
    1. Huawei Honor 8 Battery Replacement, Rear Glass & Frame: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure you spend at least 5 minutes heating up the adhesive. Prying off the glass cover too early can result in cracking the panel.
      • Using a heat gun or hairdryer, apply heat approximately three inches above the glass panel to warm up the adhesive around the outside edge of the phone.
      • Make sure to apply heat evenly across the outside edge of the device.
    2. Huawei Honor 8 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Be careful not to tear the orange ribbon wire when removing the back panel.
      • Using a plastic opening tool, gently pry up a corner of the rear glass panel.
      • Slowly slide the plastic opening tool around the outside of the glass panel to break through the adhesive.
      • Additional plastic opening tools can be used to help separate the back panel from the phone body.
      • Gently lift the back panel off once all the adhesive has been removed.
    3. Huawei Honor 8 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a Phillips PH00 screwdriver, remove the silver Phillips 3.5 mm screw circled in red.
      • Using a spudger, gently lift off the small metal tab that was held in place by the screw.
      • Gently pry off the orange ribbon wire on the back panel.
    4. Huawei Honor 8 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Keep the tiny screws on a magnetic pad or a designated area so they will not be lost. There are eighteen screws in total.
      • Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
      • Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
      • Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
      • Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
      • Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
    5. Huawei Honor 8 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slowly slide the plastic opening tool around the perimeter of the inner lining.
      • Additional plastic opening tools can be used to help separate the inner lining from the phone body.
      • Gently pull the inner lining up to remove it from the phone body.
    1. Huawei Honor 8 Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Honor 8 Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Honor 8 Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Holding the phone so that the cameras are at the top, locate the small hole on the top right edge of the device.
      • Using the 0.8 mm Sim Eject tool, push down on the small hole to release the Sim Card tray.
      • Gently pull out the Sim Card tray and set it aside.
    2. Huawei Honor 8 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • In the following steps you will disconnect the five connectors circled in red holding the motherboard in place.
    3. Huawei Honor 8 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull the small ribbon connection between the battery and motherboard upward to disconnect it.
      • Use a spudger to help pry off the connection if necessary.
    4. Huawei Honor 8 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to gently pry off the small antenna cable on the right side of the motherboard.
    5. Huawei Honor 8 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a spudger, gently pry up the small connection that holds the motherboard in place.
    6. Huawei Honor 8 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a spudger, gently pry up the connector near the left edge of the motherboard.
    7. Huawei Honor 8 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to gently pry off the small connection on the far left edge of the motherboard.
    8. Huawei Honor 8 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pry up a corner of the motherboard.
      • Lift the motherboard to remove it from the body of the phone.
    1. Huawei Honor 8 Battery Replacement, Battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 8 Battery Replacement, Battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a spudger, pry off the small connection between the speaker and phone body located near the bottom of the device circled in red.
      • Gently pry up a corner of the speaker using a spudger.
      • Lift the speaker up and out of the phone body.
    2. Huawei Honor 8 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Avoid using a heat gun for this step as overheating the battery can cause permanent damage.
      • You may use an iOpener on the front side of the phone to safely heat and loosen the adhesive under the battery.
      • Insert the plastic spudger into the gap between the frame and the battery.
      • Move the spudger around the outside edge of the battery to remove the adhesive.
      • Do not bend or puncture the battery. There is a lot of adhesive holding the battery in place, moving the spudger may require some effort. Use the plastic opening tools to help pry each side open.
    3. Huawei Honor 8 Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Honor 8 Battery Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once all the adhesive has been removed from the battery, use the spudger and plastic opening tools to gently pry the battery away from the frame.
crwdns2935229:042crwdne2935229:0
Kevin Shu
crwdns2935283:009/25/17crwdne2935283:0
239 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G2, Forte Fall 2017 crwdns2935289:0Cal Poly, Team S18-G2, Forte Fall 2017crwdne2935289:0
CPSU-FORTE-F17S18G2
crwdns2947412:024crwdne2947412:0
Where are the battery installation and reassembly instructions?
Nate Gardner - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Just go back in reverse order, Einstein
cherry blossom - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I replaced the battery on my Huawei Honor 8 and after power up it doesn’t see the SIM card. There’s no way to install the sim card tray backwards or put the SIM card in wrong. Any ideas?
gaildagan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Never mind. I figured it out. The metal SIM card cage got distorted and the tray was sliding in behind it, not into it. I gently bent the cage back into shape and all is well.
Do I need to apply new adhesive ? or re-use what is already on the device?
Qing Li - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 41,437
