If your screen becomes cracked or is inoperable, the front display panel will need to be replaced. This process involves removing nearly every component of the phone before gaining access to the front display panel.
Insert the SIM Card Eject Tool into the SIM card tray hole.
Press the eject tool into the hole until the tray clicks open.
Remove the SIM tray from the device using two fingers.
Remove the SIM card from the compartment using two fingers.
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Slide the opening tool or spudger along the bottom of the phone and around the edge.
Once three sides of the screen are detached, pry the phone apart using two hands.
Remove the five 4mm Phillips #00 screws using a screwdriver.
Remove the motherboard cover from the device using a spudger or your fingers.
Remove the four connectors by placing the spudger between the motherboard and the connectors.
Press upwards against the connectors until they disconnect.
Remove the battery by first prying a spudger between the battery and the screen.
Slice through the adhesive by pushing card around and underneath the battery.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Using the plastic card, remove the battery by lifting it from the casing.
Remove the last two connectors from the motherboard using a spudger or your fingers.
Remove the four 2mm Phillips #00 screws.
Gently lift the motherboard from the phone using two fingers or a spudger.
Remove the speaker using the tip of a spudger.
Remove the five 2mm Phillips #00 screws using a screwdriver.
Remove the two 2mm #5 Torx screws using a screwdriver.
Remove the metal plate from the vibrator assembly using a spudger.
Snap the two connectors off using a spudger or your finger.
Pry the micro USB port off of the phone using a spudger.
Pry the speaker and microphone assembly off of the phone by sliding a spudger down along the bottom.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull the volume buttons off using tweezers or the end of a spudger.
crwdns2935229:012crwdne2935229:0
