If the front camera on your device is failing or blurry you may need to replace the assembly. This guide will follow you through the steps required to open your device to get to the front camera.
Insert the SIM Card Eject Tool into the SIM card tray hole.
Press the eject tool into the hole until the tray clicks open.
Remove the SIM tray from the device using two fingers.
Remove the SIM card from the compartment using two fingers.
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Slide the opening tool or spudger along the bottom of the phone and around the edge.
Once three sides of the screen are detached, pry the phone apart using two hands.
Remove the five 4mm Phillips #00 screws using a screwdriver.
Remove the motherboard cover from the device using a spudger or your fingers.
Pry the seven connectors off using a spudger or your finger.
Remove the four 2 mm Phillips #00 screws.
Lift the motherboard off of the phone using a spudger or two fingers.
Remove the cable connecting the camera from the motherboard using a spudger or your finger.
Remove the front camera out from the motherboard by pushing on it with the tip of a spudger.
