Huawei Honor 6x Battery Replacement
  1. Huawei Honor 6x Battery Replacement, SIM Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the device.
  2. Huawei Honor 6x Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 6x Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Battery Replacement, Back Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 6x Battery Replacement, Back Cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Honor 6x Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Honor 6x Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 6x Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Honor 6x Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Honor 6x Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard cover from the device using a spudger or your fingers.
    Always wear ESD Gloves before handling Motherboard.
    anti-static or electrostatic discharge (ESDgloves protect workers and the environment around them .
    Imran Khan - crwdns2934203:0crwdne2934203:0
  10. Huawei Honor 6x Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 6x Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four connectors by placing the spudger between the motherboard and the connectors.
    • Press upwards against the connectors until they disconnect.
    • The connectors will make a "click" sound when disconnected.
  11. Huawei Honor 6x Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 6x Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by first prying a spudger between the battery and the screen.
    • Slice through the adhesive by pushing card around and underneath the battery.
    • The adhesive is fairly strong, so make sure to press firmly against the adhesive.
    • Do not excessively bend the battery. Bending the battery too much can cause it to break and even catch fire.
  12. Huawei Honor 6x Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Honor 6x Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Plastic Cards
    $2.99
    • Using the plastic card, remove the battery by lifting it from the casing.
crwdns2935229:016crwdne2935229:0
Hudson Brooks
crwdns2935283:010/08/18crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S13-G5, White Fall 2018 crwdns2935289:0Cal Poly, Team S13-G5, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S13G5
Where do i get its original battery, its mostly fake batteries out there in online stores
satyanarayan debbarma - crwdns2934203:0crwdne2934203:0
@satyanarayan+debbarma
I used this battery I found on Amazon. It wasn’t the original, by Huawei, but it’s the exact same thing. Works perfectly fine.
https://www.amazon.com/gp/product/B08LZC...
Varler - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 10,853
