Huawei Ascend Y300 Battery Replacement
  1. Huawei Ascend Y300 Battery Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Ascend Y300 Battery Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Ascend Y300 Battery Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, you want to flip the phone screen facing down. To remove the rear cover located on the back of the phone, you must grip on the gap located at the bottom of the phone. Lastly, pull up!
  2. Huawei Ascend Y300 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In order to remove the battery, you must first locate the gap intended for removal above the battery. You will then push down using the tip of your finger while also pulling outward to remove the battery for replacement.
  3. Huawei Ascend Y300 Battery Replacement, Replace The Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the battery is removed, you must replace the battery using the new one. To insert the new battery you must align the connection between the battery and the device. Lastly, you will push the bottom of the new battery until it is sitting inside the intended station.
    • This will be your new source of power.
To reassemble your device, follow these instructions in reverse order. After you have inserted the new battery, simply, replace the back cover and began pushing down on the cover until it snaps into place.
crwdns2935229:010crwdne2935229:0
Anthony Ng
crwdns2935283:010/19/14crwdne2935283:0
1,448 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 crwdns2935289:0UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014crwdne2935289:0
UMASSD-VIJAYBHASKAR-F14S5G3
crwdns2942667:0crwdne2942667:0 5,820
