Huawei Ascend G7 is not difficult to take apart, but some parts are glued and need attention
Under the top frame there are 3 screws. The frame is glued. Heat without exaggerating the frame and lever to disengage.
Remove the 3 screws
Under the Lower frame there are three screws. The frame is glued. Heat without exaggerating the frame and lever to disengage.
This is the same as removing as removing the upper frame casing
Remove the door of Sim
Remove the cover of the SD Card.
Use a prying tool to pry the display away from the back case.
The disassembled smartphone with the aluminum back removed
Disconnect the battery connector.
If The battery is stuck, remove it very carefully.
Disconnect the video connector gently.
Gently unplug the headphone connector.
Remove the screw at the bottom.
Remove screw from the top
Remove the screw next to the video connector.
Your almost to the finish line! Just 3 more steps to go.
Gently rotate outside the motherboard, making sure not to break the little indicated connector
If your new display assembly comes with this ribbon cable already installed, disconnect the old one now.
Heat the front.
Using a plastic tool to separate the lock display / touch screen from the main body.
crwdns2935229:036crwdne2935229:0
donde puedo conseguir el remplazo de la pantalla completa, LCD + touch?
Hi , thanks this info is great . My G7 has a broken touch screen but works fine . I have seen replacement screens and units which include the digiboard ? So do I need to still remove the pcb or just the frame to get to the edge of the touch screen ? is it easy to replace the touch sreen alone ? look forward to your reply . Regards Carl.
Step 8 - the battery stock very much, I inserted a credit card in between the casing and the battery to detach it. I guess that bending the battery is very dangerous!
Step 15 - This part means the black flat cable with the three buttons ;-)
Step 16 - The new display needed a small film of glue
Hi, the power on connector on my main board has the plastic clip missing is there a way I can connect them together, they seem too small for soldering.
