The ResMed AirSense 10 AutoSet is a continuous positive airway pressure (CPAP) machine that is used to treat sleep apnea. The device automatically adjusts the pressure throughout the night to help the user maintain a clear airway.
The device is small, lightweight and easy to travel with and has several features such as built-in humidifier, advanced data tracking, and easy-to-use controls.
How to Use?
To use the ResMed AirSense 10 AutoSet, first, make sure that the device is plugged in and the humidifier is filled with water.
Next, attach the mask to the device and place it on your face. Adjust the straps to ensure a secure fit. Turn on the device and set the pressure to the recommended level. Some devices will come with pre-set pressure levels by your Doctor, but you can also adjust as needed. Once the machine is on and the pressure is set, you can go to sleep. The device will automatically adjust the pressure throughout the night to ensure that your airway remains open.
In the morning, turn off the device and detach the mask. Empty the water from the humidifier, and clean the mask and device as needed. It's important to note that the device's data tracking feature can help you and your doctor to monitor your therapy progress and make adjustments to the pressure settings as needed.
The device can also provide compliance data, which is a record of how often the machine was used and how well the therapy is working. Also, make sure to regularly clean the device as per the manufacturer's instructions, to ensure the safety and hygiene of the device and prolong its lifespan.
Using the ResMed AirSense 10 AutoSet can be a simple and effective way to manage sleep apnea. With its automatic pressure adjustments and advanced data tracking, the device can help ensure a clear airway throughout the night, allowing you to get a better night's sleep.
Additional Information
For more information visit -
There is no issue in using this machine. its very easy to use.
