How to update Kali
    • Press Ctrl + Alt + T to open the Terminal Interface.
    • To update and upgrade Kali enter the following command: sudo apt update -y && sudo apt upgrade -y
    • If you asked to restart services during the upgrades, choose Yes
    • Once the updates and upgrades are complete some of the packages won't be required. You can remove those packages with the command: sudo apt autoremove -y
    • This will allow your Kali Linux machine to run smoothly and will free up necessary storage.
    This did NOT work for me. Came back with certification verification failed and index failed to load . when i updated, it gave me kali linux 6.1 and it doesnt work. 6.0 does work though, but i have to manually log into it instead of autoload now
    Hellcast Radio - crwdns2934203:0crwdne2934203:0
    What was the exact error that you got? You can also try sudo apt-get update -y && sudo apt-get upgrade -y
    Jacob Mehnert -
In the event that you don't have the latest release of Kali Linux, or didn't install it, you're going to want to use the following command
sudo apt update && sudo dist-upgrade -y
Be cautious, as this is the equivalent a major Windows Update and can mess up a system that you have been using for a while.
crwdns2935229:019crwdne2935229:0
Jacob Mehnert
crwdns2935283:010/18/21crwdne2935283:0
39.911 crwdns2915208:0crwdne2915208:0
crwdns2935297:050crwdne2935297:0
iFanatics crwdns2935289:0iFanaticscrwdne2935289:0
Community
crwdns2931471:061crwdne2931471:0
crwdns2935297:0199crwdne2935297:0
Hello / Hallo - many thanks / vielen Dank... Top :) .... Regards / Grüße
Marco Werner - crwdns2934203:0crwdne2934203:0
En la versión de kali 2024, al realizar el dist-upgrade, me dañó la instalación.
Ejecuté sudo apt upgrade -y y me actualizó sin problemas.
Removí los programas con la instrucción supo apt autoremove -y
Mario Enrique Salguero Juárez - crwdns2934203:0crwdne2934203:0
Gracias asi es que actualiza esta version
Juan Mario Paba Gomez -
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 164
crwdns2936753:030crwdne2936753:0 780
crwdns2942667:0crwdne2942667:0 95,283
