How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables
  1. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Clean up the ends: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Clean up the ends: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use wire cutters to make a clean cut on the end of the cable you want to strip.
  2. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the mantle: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the mantle: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the cable with a stripping tool for communication cables and twist it to cut the mantle.
    • Pull off the mantle.
    • It depends on what you want to do with the wire, but usually stripping off about 5cm is a pretty good starting point.
  3. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the shielding: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the shielding: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Flush Cutter
    $29.99
  4. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the plastic foil: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the plastic foil: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Flush Cutter
    $29.99
  5. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Pull back the grounding wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Pull back the grounding wire: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back the grounding wire and wrap it around the cable.
  6. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Stripping the wire itself is optional, depending on what you want to do with it. P. ex. if you are going to punch it down into an LSA Plus block, you don't need to strip the wire.
    • Grip the wire with the 0.8 mm notch and pull off the insulation or use automatic wire strippers.
    • Stripping off 1cm is usually enough.
Good luck on your next project!
Sebastian
crwdns2935283:008/19/18crwdne2935283:0
29 252 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 220
