How to restore UV Damaged Headlights
  1. How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In a shaded area, apply masking tape on the outer edges of the headlight assembly.
  2. How to restore UV Damaged Headlights: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spray bottle of soapy water to wet the 800-grit sandpaper.
    • Spray the sandpaper liberally and make sure it is completely wet.
  3. How to restore UV Damaged Headlights: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Spray the headlight with soapy water and sand the headlight's surface.
    • Continuously spray the headlight and the sandpaper with water. The surface must stay wet during sanding.
    • Sand the headlight in a circular motion throughout this step.
    • Stop sanding when the entire headlight appears foggy.
  4. How to restore UV Damaged Headlights: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Spray the 2000-grit sandpaper with soapy water and ensure it is completely wet.
    • Sand the headlight in a circular motion while maintaining the surface wet with soapy water.
    • Stop sanding when the headlight appears slightly less cloudy (than in the previous step).
  5. How to restore UV Damaged Headlights: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    • Lightly wet a small section of a clean microfiber cloth with 70% isopropyl alcohol.
    • Rub down the entire headlight surface with the microfiber cloth.
  6. How to restore UV Damaged Headlights: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully peel off the old masking tape.
    • Use newspaper to cover the car's body using masking tape to hold it down.
    • Shield any gaps and use newspapers at least a foot long.
    • The newspaper will protect the car from overspray in the next step.
  7. How to restore UV Damaged Headlights: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a clear coat to spray the headlight.
    • Follow the clear coat manufacturer's instructions for spraying distance, number of coats, and drying time.
    • Apply the clear coat in well-ventilated conditions.
  8. How to restore UV Damaged Headlights: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a small amount of compound to a clean microfiber applicator pad.
    • Dap the headlight's surface with the compound.
    • Work the compound into the headlight.
    • Use heavy pressure and rub in a circular motion when working the compound into the headlight.
  9. How to restore UV Damaged Headlights: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wipe the headlight with a clean microfiber cloth.
    • Apply a small amount of polish onto a new, clean microfiber applicator pad.
    • Dap the polish onto the headlight, then work the polish onto the headlight.
  10. How to restore UV Damaged Headlights: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wipe the headlight with the clean side of a microfiber cloth.
    • Use a microfiber cloth to scoop about a quarter-sized amount of wax.
    • Rub the wax into the headlight with medium pressure and in a circular motion.
    • Continue rubbing until there is no more visible wax.
  11. How to restore UV Damaged Headlights: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to restore UV Damaged Headlights: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wipe the headlight with a clean side of microfiber cloth.
    • Carefully remove the newspaper and masking tape.
    • Enjoy the clear road with your newly restored headlights!
Patrick Abelgas
crwdns2935283:010/24/23crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 9-1, Ribeiro Fall 2023 crwdns2935289:0CSU Los Angeles, Team 9-1, Ribeiro Fall 2023crwdne2935289:0
Community
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 1,502
