If your watch hands aren't lining up correctly, this guide will show anybody who owns a watch with a snap-off back, how to get those hands back to the correct alignment.
To make your watch easier to work with, start by taking off the straps.
Pull down the strap until the lug can be accessed.
Pull down on the lug and it should freely come out of place.
Locate the divot on the underside of the watch.
Carefully place your thin blade in the divot and pop the buckle off of your watch.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use your tweezers to grab onto the plastic holder and gently pull it out.
Apply pressure with the pointed tip instrument at the spot circled; around where the stem meets the main part of the watch.
While applying pressure, pull the stem out and it should freely come off.
Gently place the tweezers underneath the hands of your watch.
To remove the hands, carefully pry upwards and all of the hands should pop off.
Using your tweezers place the hour hand in the center of the watch.
Press down on the hand, so that the hour hand is firmly attached to the center post.
Align the hour hand with the 3 O'clock position on your watch.
Using your tweezers again, place the minute hand in the center of the face.
Align the minute hand with the 12 O'clock position.
Press down on the hand until the minute hand is firmly in place.
Carefully pick up and place the second hand in the center of the watch.
Press down firmly so that the second hand stays in place.
crwdns2935229:023crwdne2935229:0
thanks a lot
The hands on my clock doesn't work
There could be any number of reasons for that. You could adapt this method to fix clock hands that weren’t in alignment, but it won’t help you if they just aren’t moving…
Thanks - the second hand fell off of my kid’s lego watch. It still worked, but it was important to him that the second hand moved. The trick in step 4 to get the stem off was the crucial thing that I was missing.
I’m using Seiko Sportura ,and i love its kinetic movement.I just recommend this watch.
