If you forget your Flipper Zero PIN, the only way to regain access to your device is to perform a factory reset, which will erase all data on the device, including the existing PIN. After the factory reset, you'll be able to set a new PIN and regain access to your device.
The dolphin's level, settings, and information about paired devices will be erased. Data saved on the microSD card will not be lost.
Hold the Up- and Back-buttons for 30 seconds.
Confirm the reset procedure by holding the Right-button.
Try to remember your PIN next time!
Every time I attempt this, it goes black 20 seconds in the 30 seconds and resets the locked timer.
You have to wait until the timer ends and it asks for the passcode again. Only THEN can you perform the steps. I just successfully did so after experiencing the same issue as you.
If i do the same steps my flipper says: Flipper crashed and was rebooted HardFault. What can i do? is there maybe another way ?
i got the pin for the flipper : Left Up Right Down = press Insert
