How to replace the touch IC on the home button
    • In this tutorial you will learn about fixing the home button in an iPhone 7. To find out more about iPhone repair and more check my other guides!
crwdns2935229:018crwdne2935229:0
Alex Sander
crwdns2935283:002/28/17crwdne2935283:0
39,074 crwdns2915208:0crwdne2915208:0
crwdns2935297:0201crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Do you have clear instructions and tools how to do it
Abbigail huari - crwdns2934203:0crwdne2934203:0
So do you need to move the chip to replace the home button?
Dylan McGarrity - crwdns2934203:0crwdne2934203:0
You need to reball or replace the chip to repair Touch ID.
Alex Sander -
If the home button or its flex cable is broken then it's completely shot, short of taking it to an Apple store for a replacement.
On the other hand, it could also be caused by the home button's extension flex cable running through the back of the lcd, and/or a damaged camera/speaker flex cable on top. So make sure to check all those out carefully before resorting to the Apple store.
After reading through a lot of suggestions, here's one which sounded interesting to me. Low and behold, this solution has actually worked!! I have removed that single screw completely, restarted the phone, and the home button started working perfectly.
05/31/2017 by screensaviors
I loosened the screw behind the center of the home button (holding it to the metal bracket), and it magically works now. This may not fix a lot of them, but it worked for me. I was just tightening that screw snug, but must have been too snug.
billa.4you - crwdns2934203:0crwdne2934203:0
Very good points, it will certainly help people to resolve some of their problems, thanks for sharing your experience!
Alex Sander -
crwdns2936753:030crwdne2936753:0 163
crwdns2942667:0crwdne2942667:0 37,595
