How to replace the salt container in your dishwasher
    • Watch for continuous pumping with the door open or an active Aquastop alarm.
    • Look for unexplained water under basic models that lack Aquastop.
    • Leaks usually start at the welded seam on the bottom of the salt container.
    • If these symptoms appear, plan to replace the container.
    • Unplug the dishwasher from the mains before touching any parts.
    • Spread absorbent towels around the base because residual water will spill.
    • Collect a screwdriver, adjustable pliers, towels, and a phone or camera.
    • Tilt the appliance only slightly during work to avoid stressing joints.
    • Undo the left‑hand screw securing the cover to the door frame.
    • Remove the matching screws on both sides.
    • Tilt and lift the cover away to expose the salt filler neck.
    • Keep one hand on the salt container throat to support it later.
    • Photograph every wire on the inlet valves and microswitch with a smartphone.
    • Store the images for exact reference during reassembly.
    • Unscrew and lift off the panel on the same side as the salt container.
    • Handle the attached multi‑chamber softening system carefully to avoid strain.
    • Remove the external screw that locks the container to the chassis.
    • Unscrew the inner retaining ring surrounding the filler neck; use pliers if tight.
    • If the ring binds, lift the container slightly from below while turning.
    • Support the container at all times so it does not drop when freed.
    • Detach the rubber hoses from the container base while holding it steady.
    • Remove the complete container assembly from the cabinet.
    • Inspect the lower seam for cracks or mineral stains confirming the leak.
    • Note that replacement containers ship dry, so handling is easier.
    • Reconnect each hose to the matching port on the new container.
    • Seat the container, hand‑tighten the retaining ring, then snug it with pliers.
    • Refit and tighten the external mounting screw.
    • Reinstall the side panel, reconnect wires using your photos, and fit the front cover.
    • Fill the container with dishwasher salt and add about 500 ml of water to prime it.
    • Run a short rinse programme to flush air and activate the softening circuit.
    • Always top up salt even when using multifunction tablets to prevent blockages.
    • Repairs may void warranty; confirm manufacturer terms before starting work.
With the new salt container primed and the rinse cycle completed, the dishwasher’s softening system is back in service. Keep the reservoir filled with proper dishwasher salt and repeat short rinse cycles after every refill to maintain clear, spot‑free results.
Ula Gantar
crwdns2935283:001/08/25crwdne2935283:0
6,157 crwdns2915208:0crwdne2915208:0
crwdns2935297:038crwdne2935297:0
ZEOS Slovenia crwdns2935289:0ZEOS Sloveniacrwdne2935289:0
Local Repair Groups
crwdns2935297:044crwdne2935297:0
crwdns2942667:0crwdne2942667:0 48
