If your dishwasher isn’t filling with water, continuously fills without stopping, or shows a red indicator on a mechanical aqua-stop hose, the inlet valve may be faulty.
Replacing the valve restores proper water control and prevents costly floods. This guide will show you how to identify the correct part, remove the old valve, and install a new one — all while following safety rules and protecting your warranty.
⚠️ Be sure to unplug your dishwasher and shut off the water supply before starting.
crwdns2931653:02crwdne2931653:0 Confirm the valve is faulty
Observe if water flows into the tub endlessly or if the machine shows a fill error and stays dry.
Look for blinking lights or error codes that indicate the control board cannot close or open the valve.
crwdns2931653:03crwdne2931653:0 Identify the valve type
Inspect the inlet hose to determine whether you have a standard solenoid valve, a mechanical aqua‑stop hose, or a complete electronic aqua‑stop assembly.
Buy a replacement that matches your original valve style to maintain safety certification.
crwdns2931653:04crwdne2931653:0 Expose the inlet valve
Pull the dishwasher far enough forward to reach the point where the inlet hose enters the cabinet.
Locate the solenoid valve mounted at that entry point inside the machine base.
Remove any screw or twist‑lock that secures the valve to its bracket while supporting the plastic body.
crwdns2931653:05crwdne2931653:0 Detach hose and wiring
Open the spring clamp with pliers or a flat screwdriver and slide it away from the valve nipple.
Wiggle the inlet hose off the valve while holding the fitting steady to avoid cracking it.
Pull the spade connectors straight off the valve terminals.
crwdns2931653:06crwdne2931653:0 Remove the valve body
Rotate or slide the valve out of its mounting plate and lift it clear of the dishwasher.
crwdns2931653:07crwdne2931653:0 Install the new standard valve
Seat the replacement valve into the mounting plate in the same orientation as the original.
Push the water hose fully onto the valve nipple and return the clamp to its groove.
Reconnect the two electrical terminals exactly as they were photographed.
crwdns2931653:08crwdne2931653:0 Replace a complete aqua‑stop assembly (if fitted)
Disconnect the original full aqua‑stop hose and its plug‑in wiring harness from inside the cabinet.
Feed the new hose along the same route and secure its electrical connector firmly.
Ensure both solenoids sit correctly and all hose joints are hand‑tight.
crwdns2931653:09crwdne2931653:0 Secure the assembly
Return the inlet hose to its original routing and verify the clamp seats evenly.
Fasten the valve bracket or screw so the component cannot move during operation.
crwdns2931653:010crwdne2931653:0 Restore services and test
Open the water tap and inspect all joints for leaks.
Plug the dishwasher back in and run a short fill cycle to confirm it takes in water properly and no leaks are visible.
Regularly inspect the inlet hose for a red burst indicator, shut the water tap during long absences, and keep photos of wiring for future reference. Following these habits and the steps above will keep your dishwasher filling safely and protect your kitchen from floods.
