How to replace the heating element in your glass ceramic hob
    • Pull the power plug out of the electrical socket before starting work.
    • Do not continue until you are certain the appliance is completely de‑energised.
    • Undo the four mounting screws on the underside of the worktop, two on each side.
    • Lift the hob vertically out of the cut‑out once all screws are removed.
    • Keep cables free from strain while lifting.
    • Lay a soft towel on the bench and flip the hob so the glass rests safely on it.
    • Avoid placing the glass on sharp edges to prevent scratches or cracks.
    • Confirm which cooking zone no longer heats and locate its matching element under the glass.
    • Take clear photos of the wiring layout around the faulty element.
    • Label any identical wires, particularly noting the single red lead among three white leads.
    • Pull the spade terminals off the heating element one by one using insulated pliers.
    • Mark the connection point for the red wire on the bracket to avoid mix‑ups during reassembly.
    • Undo the single central screw holding the distance spacer to the chassis.
    • Press the spring clips and lift the heating element clear of its seat.
    • Lift the element straight out of the housing once free of clips.
    • Wipe the metal housing with a clean cloth to remove grease and stains.
    • Cleaning now prevents trapped dirt from baking onto the glass later.
    • Set the new element into the housing, aligning its tabs with the cut‑outs.
    • Press down until the spring clips engage and the element sits flush.
    • Insert and tighten the mounting screw to secure the spacer.
    • Reconnect each wire to its original terminal following your photo reference.
    • Ensure each spade fully seats and no wire is under tension.
    • Rotate the hob upright, guide the cable back through the worktop and lower the unit into the cut‑out.
    • Refit the four mounting screws and tighten evenly.
    • Reconnect the power plug and test the repaired cooking zone.
    • Repairs can void the manufacturer warranty; always read your appliance manual before opening the unit.
    • For gas or induction models, contact a licensed service technician instead of attempting a DIY repair.
Your hob should now heat evenly again. Monitor the repaired zone for a few minutes; any smells or unusual noises mean power off immediately and re‑check connections. Retain all photos and notes for future maintenance and dispose of the old element at an authorised e‑waste collection point.
Ula Gantar
crwdns2935283:001/08/25crwdne2935283:0
6.157 crwdns2915208:0crwdne2915208:0
crwdns2935297:038crwdne2935297:0
ZEOS Slovenia crwdns2935289:0ZEOS Sloveniacrwdne2935289:0
Local Repair Groups
crwdns2935297:044crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 24
