How to repair broken pottery/ceramic with Kintsugi
  1. How to repair broken pottery/ceramic with Kintsugi, Arrange the broken pieces: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting Kintsugi:
    • Wash and dry each pieces of broken ceramic.
    • Like a puzzle, you arrange each piece so that they are close to their original form.
  2. How to repair broken pottery/ceramic with Kintsugi, Prepare epoxy resin: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi, Prepare epoxy resin: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi, Prepare epoxy resin: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Mix the adhesives (two tubes on the left side: green caps) on the glass tray.
    • This adhesive is called Quick 30 and is sold at Japanese DIY stores or Amazon. This is epoxy resin. The strength of the adhesive will increase when two types are combined.
    • We recommend mixing the adhesive on the glass surface to prevent it from drying out. This makes cleaning easier.
    • Apply glue to all the cracking parts. The thinner and drier the glue is, the stronger the adhesive will be.
  3. How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When the glue has dried to the point where it no longer sticks to your hands, join the pieces together. Press them firmly together so that they don't break.
    • Once everything is in place, use the tape to secure it in place. For each part that tends to spread outwards, such as flat plates or bowls, secure the entire length from one end to the other with a single piece of tape in several places.
  4. How to repair broken pottery/ceramic with Kintsugi, Clean the remaining adhesives: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi, Clean the remaining adhesives: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If there is a lump of glue, wipe it off with a cotton swab dipped in ethanol alcohol before it gets dry.
    • Check that the adhesive has been firmly fixed and that the original shape has been maintained.
    • After you have wiped off the glue from both the front and back, peel off the masking tape.
    • Another way to remove residue is to use cooking oil with a paper towel.
  5. How to repair broken pottery/ceramic with Kintsugi, Apply a mixture of Epoxy Resin: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a mixture of epoxy resin A and B to all areas where the adhesive has hardened.
    • Fill all the gaps with putty. You can sand it down later, but push it in with your fingers so that it is as thin as possible.
    • As with cleaning the glue, after applying the putty, remove the putty that has come out with a cotton swab moistened with ethanol.
    • Putty dries faster in summer and takes longer in winter.
    • The best result to attach each piece firmly is to let the adhesive surface dry to some extent before attaching.
    • Allow to dry thoroughly for at least 30 minutes.
  6. How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the putty is completely dry, scrape it off with a coarse file. After that, polish with a fine file. The degree of sanding depends on your preference for the finish.
    • File rounded together and sharpened. It will be easier to control.
    • If you like the uneven look, just a coarse file will suffice. If you want a smooth and clean look, use a fine-grit file.
    • The filing process is most important in determining the finish of the kintsugi.
  7. How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here is a tube of gold lacquer (Orange Tube) and brass powder (Gold powder case between orange tubes). Prepare the amount shown in the image (the proper amount for the actual chipped area) on the glass sheet. Do not use more brass powder.
    • Kintsugi is not only available in gold, but also in silver and black lacquer, depending on one's taste and vessels.
    • Mix the lacquer tube with the brass powder until there is no powdery residue. If the mixture dries out or needs to be thinned during the process, you can add a small amount of kerosene to the mixture.
  8. How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The amount of kintsugi to be applied depends on your preference. It is also possible to apply more to give a little thickness.
    • Image 1 &2: Front and back of the plate. The front is a thin layer of epoxy resin. Do not apply a thick coat. When applying the kintsugi, the speed is one millimeter per second.
    • Image 3: A plate with chipped rim. In this case, put epoxy resin in the chipped area, file it after it dries, and apply a thin layer of lacquer over it.
  9. How to repair broken pottery/ceramic with Kintsugi, When kintsugi is used for fixing a broken mug handle: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi, When kintsugi is used for fixing a broken mug handle: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to repair broken pottery/ceramic with Kintsugi, When kintsugi is used for fixing a broken mug handle: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Arrange the broken cup handle correctly, like you were trying to fit a puzzle together. Apply a thin coat of epoxy resin to both sides of each piece.
    • When the epoxy resin is slightly dry, start to attach the broken handle together. It is recommended that you work with someone to do this for more stable work. Each time you do this, use washi (painters) tape to secure it tightly in place.
    • This process may require several attempts. Do not give up and use washi tape to secure it back to its original shape. Leave it for 15-20 minutes to let it completely dry.
    • Once you are sure it is completely dry, carefully peel off the washi tape and gently sand it with a file.
    • As described in the previous step, carefully apply mixed lacquer and gold powder over the epoxy resin.
    • Now your broken coffee cup is reborn as a unique, one-of-a-kind entity!
Admire the unique patterns of your repaired piece, each crack telling a story of resilience and beauty.
Midori Doi
crwdns2935283:011/16/15crwdne2935283:0
313 491 crwdns2915208:0crwdne2915208:0
日本出身者として、いずれiFixitで金継ぎの技術を紹介したいとずっと思っておりましたので、本ガイドの執筆公開に深く感謝します。興味深く拝読いたしました。
細かいことですが、気になったことがあります。「伝統的な金継ぎでは接着にも(日本などで使われるウルシオールを主成分とした)漆を使う」点と「(少なくとも日本の法令上は)エポキシ接着剤による金継ぎをした食器を食事に使うのは安全上問題がある可能性が高い」点の記載がされていないことです。
伝統的な金継ぎでは接着にも漆が使われており、この場合は金継ぎ後に食事に使用しても問題はありませんし、保管条件次第ですが数十年数百年レベルの耐久性もあります。ただし、漆の硬化条件が厳しい(環境条件は諸説ありますが、金継ぎの接着に使う場合は「気温20〜30°C湿度60〜90%で2週間」が目安か)上、漆自体の扱いが難しくヒビや欠けの修理に別の材料や手順が必要になることから、接着に漆を使う金継ぎについては具体的な手順の紹介を避けて、「本来は接着にも漆を使う」旨の追記があれば十分かと思います。
食品衛生法規については国や地域によって異なるので、ここでは日本の場合について書いておきます。食器などに使って良いとされる材料は食品衛生法に基づいて決められており、食器用として使って良いとされる接着剤には「食品衛生法適合」などと謳われているはずです。ですので食品衛生法適合品のエポキシ接着剤であれば問題ないのですが、市販のエポキシ接着剤はほぼ不適合品だと思いますので注意が必要です。表面仕上げ用の金粉にもこの規制は適用されますので、安全に食事に使えるようにするには真鍮粉ではなく純金粉(など)を使う必要があり、その場合は使う材料と工程が変わってきます。(なお、食品衛生法はあくまで営業目的の場合が対象なので、個人使用する分には違法にはなりません(個人使用目的の食器を使って他の人が食事をして健康被害などが出た場合どうなるのかは分かりません))
細かい話をしましたが、食事に使わない鑑賞目的であれば本ガイドの手順で問題ないかと思います。執筆公開お疲れ様でした。
Servause - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 570
