How to repair a Tipp-Ex Pocket Mouse 10m
  1. How to repair a Tipp-Ex Pocket Mouse 10m, Opening the housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the red tab at the top of the housing or pull it off.
    • Use a screwdriver to carefully open the housing. Be careful not to use too much force so as not to damage the plastic or the pins.
    • Remove the top of the housing to expose the inner workings of the mouse.
  2. How to repair a Tipp-Ex Pocket Mouse 10m, Remove the rubber: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the rubber that ensures the rollers roll up and down smoothly.
    • Make sure that the rollers do not come off.
  3. How to repair a Tipp-Ex Pocket Mouse 10m, Cutting the tape: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the front, small and probably very full roll and unwind about 5 cm of ribbon.
    • Cut the ribbon.
  4. How to repair a Tipp-Ex Pocket Mouse 10m, Cleaning the reel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all plastic tape waste from the reel.
    • It is best to roll the waste directly into the waste garbage can.
  5. How to repair a Tipp-Ex Pocket Mouse 10m, Reattach the tape: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut a 3 mm wide strip of scotch tape.
    • Use it to stick the Tipp-Ex tape back onto the roll.
    • Wind a few turns onto the roll.
  6. How to repair a Tipp-Ex Pocket Mouse 10m, Inspecting and tensioning the belt guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the belt guide and tension of the belt.
    • Hold the encoder roller firmly and tighten the belt with the waste roller.
  7. How to repair a Tipp-Ex Pocket Mouse 10m, Closing the housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the mouse back together and press the lid firmly onto it.
    • If plastic parts were ruined when opening, you can glue them shut.
Your Tipp-Ex Pocket Mouse is now repaired and can be used again until the tape in the encoder roll is actually empty.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
thst71
crwdns2935283:006/04/16crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
I dun get a single ting. Very unclear
Albrt einstein - crwdns2934203:0crwdne2934203:0
Very bad. Not clear. Cannot understand.
Die Beschreibung ist absolut korrekt. Danke!
Angéla Schenk - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 67
crwdns2936753:030crwdne2936753:0 335
crwdns2942667:0crwdne2942667:0 37,525
