How to repair LG G5 Power button ?
crwdns2937549:0crwdne2937549:0
crwdns2935229:014crwdne2935229:0
Witrigs
crwdns2935283:011/24/15crwdne2935283:0
70.706 crwdns2915208:0crwdne2915208:0
crwdns2935297:0377crwdne2935297:0
crwdns2947412:012crwdne2947412:0
Does this cover the power button not functioning? The fingerprint but is vibrating but wont turn the phone on?
mrs_johnson79 - crwdns2934203:0crwdne2934203:0
My power button had been working only intermittently and then almost not at all. The solution was amazingly simple. I wet a Qtip with alcohol and rolled it around the edges of the button, pushing in as much as I could. Each time I did that the button started working better and better. Now it works perfectly. I think between humidity, finger oil and dust, it just got dirty inside.
Simintov - crwdns2934203:0crwdne2934203:0
This alcohol qtip comment helped. Button works again!
Sarah Young - crwdns2934203:0crwdne2934203:0
I had the same problem with my LG G5.  I was very skeptical about the alcohol qtip idea but was all out of ideas and decided to give it a try.  After rubbing it with the qtip for about 5 seconds the button started to work again.  Unbelievable!  Thanks for the great tip.
Craig Meyer - crwdns2934203:0crwdne2934203:0
Well %#*@. The alcohol and q-tip trick worked! I’m floored. I’ve been double-tapping since two months after I got the phone. I used cleaning alcohol, like that for wounds (70%), and pressed the button in with the saturated q-tip while scrubbing around and on the edge. As the above comments mentioned, repetition resulted in increased success: I used a total of one and a half q-tips, and applied alcohol about 3 or 4 times. No disassembly required.
Alexandra Ramsey - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 32,729
