How to remove and clean Arbor Rally Longboard bearings
  1. How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the half inch wrench to remove the nut on each wheel. Then remove each wheel.
    • Be careful not to lose the washers that sit between the nut and wheel, they are small and hard to find after you lose them.
  2. How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to remove the bearings from both sides of each wheel.
  3. How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the bearings in soapy water and let them soak for 5 minutes.
  4. How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wipe off the dirt from each bearing and dry them thoroughly with a paper towel.
  5. How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a few drops of lubricant to the inner portion on both sides of each bearing.
    • Spin the bearings and wipe off any extra lubricant that has not settled in.
  6. How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the bearing into the wheel by applying even pressure with your thumb.
  7. How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Spin the wheel to make sure that the bearings are properly aligned and running smoothly.
  8. How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to remove and clean Arbor Rally Longboard bearings: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the wheel on the axle followed by washer and then the nut.
    • Tighten the nut with your fingers as much as you can first and then use the wrench to finish the job.
    • Do not tighten the nut too much or else the wheel will not be able to spin. You should be able to slightly shake the wheel up and down along the axle.
Casey Barbello
crwdns2935283:007/24/13crwdne2935283:0
187 crwdns2915208:0crwdne2915208:0
UC Santa Barbara, Team 1-6, Bradley Spring 2013 crwdns2935289:0UC Santa Barbara, Team 1-6, Bradley Spring 2013crwdne2935289:0
UCSB-BRADLEY-S13S1G6
Great guide! I was trying to figure out how to pop the bearings out - the needle nose pliers did a great job.
jewbot007 - crwdns2934203:0crwdne2934203:0
It is usual practice to clean bearings with alcohol or a citrus cleaner; the latter is safer but more likely to leave residues. Since a citrus cleaning is water-based, you must quickly dry your bearings in order to prevent rust.
Mark Daniels - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 12,963
