How to refurbish performance skateboard bearings
  1. How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn your wrench to the left to remove the wheel nut.
    • Take the wheel off of your trucks by pulling.
    • Keep all nuts and spacers in separated, designated areas.
    • Wear gloves. You are working with messy materials such as gasoline.
  2. How to refurbish performance skateboard bearings: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to refurbish performance skateboard bearings: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly lever the bearing out using your screwdriver.
    • Do not be overly forceful to avoid scratching the bearing.
  3. How to refurbish performance skateboard bearings: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Soak the bearing in a cup with premium gasoline for 5 minutes.
    • Soak each bearing separately so none are lost or dented.
  4. How to refurbish performance skateboard bearings: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to refurbish performance skateboard bearings: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to refurbish performance skateboard bearings: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the bearing out of the gasoline and remove one side of the outside plastic locks by applying pressure on the inner ring and prying up.
    • Make sure you can clearly see and access the ball bearings.
  5. How to refurbish performance skateboard bearings: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your toothbrush to clean the bearings by using a gentle back and forth scrubbing motion.
    • Rinse the bearing with water and let dry for 5 minutes.
  6. How to refurbish performance skateboard bearings: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to refurbish performance skateboard bearings: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once dry, pick up your bearings with two fingers and drop 2 drops of skateboard lubricant into the bearing.
    • Spin the bearings immediately to spread the lubricant evenly.
  7. How to refurbish performance skateboard bearings: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to refurbish performance skateboard bearings: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to refurbish performance skateboard bearings: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a paper towel to remove excess lubricant.
    • Replace the plastic guard.
To reassemble your device, firmly put bearings back into your wheels and tighten them back down onto the trucks.
Luke Marshall
crwdns2935283:004/09/15crwdne2935283:0
126 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 30-2, Green Spring 2015 crwdns2935289:0Cal Poly, Team 30-2, Green Spring 2015crwdne2935289:0
CPSU-GREEN-S15S30G2
crwdns2942667:0crwdne2942667:0 6,051
