How to reduce ChiliCube noise level by replacing fans
  1. How to reduce ChiliCube noise level by replacing fans, Unhook cube from power and from pad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Unhook cube from power and from pad: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug from power.
    • Unhook the circulating tube.
    • You may want to have a small container available to put end of tube in, often it will leak a bit before the stopper valve retracts.
  2. How to reduce ChiliCube noise level by replacing fans, Drain cube?: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Its up to you whether you empty the cube first. If you do not, put it on a low baking pan to contain any drips. The advantage to not emptying is that you can then test the fans before final assembly. (The pumps and fan will not run if the reservoir is empty.)
    • If you decide to empty it, take cube to sink and unscrew cap and empty out water from unit.
    • You may want to stick your fingers in the two circulating tube holes to open up those valves so that you can drain water from the pump side of the unit.
  3. How to reduce ChiliCube noise level by replacing fans, Flip and Remove screws holding case together: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Flip and Remove screws holding case together: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Flip and Remove screws holding case together: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip unit over.
    • Slide razor blade under the QC sticker, it hides one of the screw holes. You should park it on top of one of the labels for future use. That is if you wish to pretend you have not opened a device you own.
    • Remove 10 screws. Four of them are in deep narrow holes which presumably are intended to prevent casual repair like this. You will find most regular #2 philip's screwdrivers are not long and/or narrow enough.
    • The hole the red arrow is pointing to, is not a screw hole.
    • The #2 Philips screwdriver must have a shank at least 8" long. If you have an insulated electrician's driver which might be long enough, it is probably too wide for the hole.
  4. How to reduce ChiliCube noise level by replacing fans, Remove bottom part of case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once unscrewed, you can lift bottom part of case off cube.
  5. How to reduce ChiliCube noise level by replacing fans, Remove connection to top of case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Remove connection to top of case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a small circuit board attached to the top part of the case for buttons and display readout. It is connected to the main circuit board on the unit by a small cable.
    • Unhook connector this small ribbon cable from the main circuit bord on the bottom of the unit (which is now facing you.)
    • The connector should pull out without needing to be released in any way.
  6. How to reduce ChiliCube noise level by replacing fans, Remove cube mechanism from top part of case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Remove cube mechanism from top part of case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip cube over (carefully supporting the inside mechanism--its not attached to the case anymore) and then lift case off. Don't go yanking it away brusquely, that control cable may have gotten pinned underneath even though you disconnected it.
    • Flip the cube over again, so those circuit boards and pump are face-up again.
  7. How to reduce ChiliCube noise level by replacing fans, Fan bracket/shroud removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Fan bracket/shroud removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • These instructions are written as if you were only replacing one fan, but you may want to do these steps to both fans at the same time.
    • The 2 screws supporting the fan are on the heat sink side of the bracket/shroud, so we remove the bracket first, so we can get to those screws next.
    • Remove four screws holding the bracket/shroud to the heat sink.
    • Tilt the bracket/shroud out. It may take a little more force than you would like. Thats OK. Try sliding it side-to-side as well.
  8. How to reduce ChiliCube noise level by replacing fans, Detach fan from bracket/shroud: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There will probably only be two of those stubby fan screws per fan.
    • Note that this is actually a photo of me installing the new fan, the old ones are white.
  9. How to reduce ChiliCube noise level by replacing fans, Cut old fans  loose: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You have several choices as to how much of the original wiring to re-use. See my Teardown for more detail on the fan wiring. Unfortunately this device is designed to make it almost impossible to replace the fans neatly.
    • In every method, you will be cutting the cables leading to the fans.
    • You can either re-use the existing female 2-pin connector, or buy a new one. These instructions are written assuming you bought a new connector, and are wiring the fans with a new harness.
    • This method has the advantage that you can test the fans/harness assembly before you re-assemble the whole kazoo, fill it up with water, and then find it does not work. (...And rinse, and repeat, and rinse and repeat, in your author's case. )
  10. How to reduce ChiliCube noise level by replacing fans, Prepare cables on new fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Prepare cables on new fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The new fan in this guide is an Antec TriCool 92mm computer case Fan, with 3-speed switch. If you get another 92mm fan, just skip the instructions for the 3-way switch placement.
    • On this fan, I first attached the "dongle" that adapts the 3-pin connector on the fan to the 4-pin old-school molex connector. This is to help figure out which conductors are positive, negative, and speed sensor, because the new fans did not have color-coded conductors. (The speed sensor will not get used here)
    • Mark on you new fan which conductor is black (negative), and which is positive (red).
    • Once you have marked the cable, cut the 3-pin connector off.
  11. How to reduce ChiliCube noise level by replacing fans, Cable up new fans and connector: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Crude drawing of how you need to cable the fans up. I'll leave it up to you how you do it. Splice using crimps, or solder with shrink tubing to cover. Give yourself plenty of extra length on the cabling, you'll need more than you might think.
    • As written the 3-pin to 2-pin adapter in the parts list is going to be cannibalized, you only really need need the single 2-pin connector, and you will discard the 3-pin connectors.
    • You could leave the new fan's connectors attached, and rig this up so if one of the new fans fails, you only need to replace the fan without cutting wire, but then you will need to two 3-pin to 2-pin adapters per cube.
    • Once you have the two fans and connector assembled, test them to see if they are connected correctly by testing the resistance between black and red at the connector using a voltmeter. If you have got it cabled right, it should not be an open circuit, there should be some resistance there.
    • Of course, if you have got a 24V DC supply, you could test them that way too, or even hook them up to the cube, plug it in, and turn it on (it will have to have water in it, and be turned right-side up, and have the control board plugged back in.)
  12. How to reduce ChiliCube noise level by replacing fans, Attach fan so 3-way switch will reach: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Attach fan so 3-way switch will reach: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you do go with the 3-speed fan used here, look ahead in instructions to see where the switch gets positioned, then attach fan appropriately to the bracket/shroud plate.
    • Note direction fan is attached. The side with cable lead-in to motor, (and usually the only label or fancier of the two hub labels), that side faces inward towards the heat sink, and the bracket/shroud plate.
    • Don't freak out if you think you can't fish the cable through the shroud the right way. You can pass the whole fan through the shroud hole on the 45º.
  13. How to reduce ChiliCube noise level by replacing fans, Re-attach fan bracket/shroud plate: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • It seems to go on easier than it came off.
    • Note cable for 3-way switch goes around corner to right. The fan in this photo was made with slightly different cabling arrangement than described in text.
  14. How to reduce ChiliCube noise level by replacing fans, Create spot for 3-way switch: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Create spot for 3-way switch: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Create spot for 3-way switch: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Caution. By cutting this flange (and drilling the holes in the next step), you will defeating a safety feature of this unit. In the case of internal leaks, or a water spill by the filler neck, water may now not be captured by the deck, and would be able to flow down onto the electronics area.
    • If you wish to retain the water retainment safety feature, install the 3-way switches differently, or use switchless fans.
    • The 3-way switch will be positioned so that you can use a pencil point poked through the grill to change the setting after your ChiliCube is re-assembled.
    • You can use a dremel tool to cut part of the flange surrounding the deck. Position the switch and mark, it will be just behind the grill on the front-side of the cube when it is upright.
  15. How to reduce ChiliCube noise level by replacing fans, Cable tie down the 3-way switches: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Cable tie down the 3-way switches: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Cable tie down the 3-way switches: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Again, if you are going to keep the water retaining safety feature, do not drill these holes.
    • It might be possible to use silicon caulk to seal these penetrations, and around the switches. It is just very hard to verify the security of those seals.
    • Drill two small holes on each end of the where the switch will go, and then loop a cable tie through to hold the switch in position.
  16. How to reduce ChiliCube noise level by replacing fans, Test again?: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you have not tested the fans yet, it is recommended that you attach the connector to the fan header on the circuit board, put water in the tank, temporarily re-attach the connector for the ribbon cable to the control panel.
    • You will have to have to turn the cube over to be right-side up so that the float switch lets the unit sense that there is water in the reservoir. This means that the cube will be sitting on top of those open circuit boards.
    • Just be careful about putting your hand near that power supply when you have this plugged in!
    • ...And if you have been resting this on a cookie sheet, find a towel or something else non-conductive so that it is not resting on metal, before you plug it in.
    • Having done all of that, when you plug it in, and turn it on using the control panel on the top, the fans should spin.
    • Please consider clicking on the "AtaBoy" button below even if you are not going to do the fix. This article took a ridiculous amount of my time to photo and write, and its nice for me to see how many people have read it (42 so far!) If you do the fix, please comment below (plus or minus), you'll be helping the next person a lot. Pay forward!
  17. How to reduce ChiliCube noise level by replacing fans, Cable tie everything and re-assemble: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reduce ChiliCube noise level by replacing fans, Cable tie everything and re-assemble: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the unit after testing, disconnect the ribbon again, and turn it upside down again.
    • Tie down that new cable, so it does not wander.
    • You may find that the 3-way switches seem to be getting too much pressure from the covering grill, if so, you can trim away one rib of grill on each side to protect the switches.
    • Experiment with the 3-way setting for the fans. Medium seems to work just fine, but if you really do not like noise, start with low. At this point, the pump and third fan are beginning to make more noise overall.
    • If you have your temperature setting to "LO", you may need to set the fans higher to maintain the maximum dissipation of heat.
    • If you have sudden hot flashes which need immediate cooling, you may need the fans on high, although the thermal mass of the whole system should moderate those heat swings.
    • Users who select a higher target temperature (especially one above the ambient), will probably find they do not need the higher speeds.
crwdns2935229:041crwdne2935229:0
Netmammal
crwdns2935283:004/30/15crwdne2935283:0
2.347 crwdns2915208:0crwdne2915208:0
Local Hero Tech Support crwdns2935289:0Local Hero Tech Supportcrwdne2935289:0
Business
crwdns2947412:044crwdne2947412:0
I was searching for information on the cube to try see if I could add some wifi or bluetooth control through an Ardiuno or something.. Good work on the guide.!!!
ronkloiber - crwdns2934203:0crwdne2934203:0
Would you share what connections you found/tried for connecting to Arduino type stuff? (Or didn't find)
Dan Bowen -
Dan Bowen, I had not done anything with the WIFI / Bluetooth interfacing, but I just tore down my Cube2 I’ve had just over 2 years. The pump is making wierd sounds. Took it apart and found the shaft end that’s burried deep inside, is worn, but not evenly all around. It worn from 1 side to the center, if that makes sense. Almost like the magnetic pull was pulling the shaft/armature to one side. What I also found is a 433mhz receiver module that I was able to find online. It uses ASK (Amplitude Shift Keying) communication that uses a 433mhz carrier sine wave. To send 1’s and 0’s they send the carrier or not. A decoder is I found this video of a guy explaining it, and using Arduino’s do transmit/recieve a signal. I figure if I can decode the info being send by the Cube remote, I might be able to build a interface using a ESP8266 with built in wifi and a 433mhz transmitter module to send the codes to the cube. Here’s the video: https://www.youtube.com/watch?v=b5C9SPVl...
ron klo -
Also to note, my “good” cube that I bought from Chili has the 433mhz module, while the cube I bought off ebay has some other type module that I could not find info on.. and that ebay cube has a communication problem. It won’t connect with a remote (I have 3 remotes, all work on my good cube). 433mhz modules I bought (99 cents !!!) https://www.banggood.com/315MHz-433MHz-L...
ron klo -
Thanks for this guide! I'm just looking to replace the O-rings, but the photo's helped!
Shawn Johnson - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 160
crwdns2942667:0crwdne2942667:0 17,804
