If you leave a light on or leave a car foo too long without drive it may happen that your battery runs completely flat. In this case your central lock will not function and you need to open it with a key.
Unlock the drivers door with a key
Check if any lights are on. Turn them off
Open the hood
If you have a multimeter - check the voltage on your battery. Anything above 12 is good (this means your problem is not the battery).
If it is close to 0 it means that something is still draining on it (probably a light is on)
You can jump start the car by connecting it to another battery, car or booster battery (see other guide on how-to). You can also charge existing battery if you have a charger. Use any available option.
Once you connect the power the alarm may go off (depending on how you opened the car)
To disable alarm, before you put a key into ignition, lock and close all doors and unlock it with a key from the outside. This should stop the alarm.
If this did not work or you already have a key in ignition you can disable the horn by removing the corresponding fuse (see pic which one). There is also a tool for removal in the compartment
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Additionally it may happen that the gearbox is stuck and does not allow you to move it
For this there is a unlocking mechanism under a cap, from the right side.
Pull it up using a plastic card or something similar
Then push down on the middle part (eg. with a key)
if you used a boost you want to drive for at least 30 minutes for your battery to pick up some charge
use the gearbox in 'S' position for this drive - it disables the engine start/stop feature and also keeps the revs higher, thus the battery will charge faster.
Check again if you have left any missing ligts on which may have drained your battery
If you find the battery flat again, and no light have been left on - show your car to a mechanic. You may either have a dead battery or problem wth a charging circuit.
Punch your code into the radio to unlock it (simply press numbers 1-6 in secuence). Code is 5 digits long.
crwdns2917034:0crwdne2917034:0
Hello I have honda insight 2011 My car doors can't be unlocked with its key remote. I even changed the battery for the remote but still same problem. So might be the car battery itself which might be dead or low as I cahnged it 4 years ago but how can I open the bonnet to change or check the battery without having access inside my car . Can you tell me where is spot in my car to use my key to open the door
