Installing a shower filter for a showerhead is not a complicated process. Most people can do it at home by themselves with the right process. Before diving into this guide, here are some things you might need to know:
- Special Requirements: Ensure the filter you've chosen is compatible with your showerhead. Different brands and models might have slight variations, which might require different installation methods.
The entire process will be divided into the following steps - Safety and Hazards: Although the installation is relatively straightforward, safety should always come first. Avoid working in slippery conditions, make sure the shower is turned off during the process to prevent splashes that could lead to slips.
- Why Install a Filter?: A shower filter can help remove impurities from the water, such as chlorine and heavy metals, making the shower water cleaner. It's a good choice for those with sensitive skin or those looking to protect their hair from potential contaminants.
The entire process will be divided into the following steps to make it easier for you to understand and execute.
Begin by unscrewing the shower head from its original water outlet.
Take out the shower filter and rinse it under a faucet (either in the bathroom or any other location) for about 30 seconds to wet the internal filter layer.
Install the shower filter onto the water outlet by turning it clockwise.
Turn on the water after installation to check for leaks.
Connect the shower head to the shower filter for installation (it's best to use a wrench).
After securing it, check again for any water leaks. If there is a leak, use waterproof tape as before.
Please check for leaks after the installation is complete.
To reassemble your device, please follow these instructions in reverse order.
