How to flash MNT Reform LPC firmware
  1. How to flash MNT Reform LPC firmware, Remove Bottom Plate Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
  2. How to flash MNT Reform LPC firmware, Remove Bottom Plate: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
  3. How to flash MNT Reform LPC firmware, Set LPCPROG switch to ON: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to flash MNT Reform LPC firmware, Set LPCPROG switch to ON: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or your fingernail to set the DIP switch LPCP to ON.
    • The LPCP switch is located on the motherboard, between the CPU module and trackball or trackpad.
  4. How to flash MNT Reform LPC firmware, Press LPCRESET: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or your finger to press the LPCRST button next to the DIP switch from the previous step.
  5. How to flash MNT Reform LPC firmware, Plug in a USB cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect a Micro-USB cable into the LPC USB port.
    • On newer revisions of the Reform, the Micro-USB port has been replaced with a USB type-C port.
  6. How to flash MNT Reform LPC firmware, Flash the LPC firmware: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug the other end of the cable into another computer. The system controller's memory appears as a virtual flash drive on that computer.
    • Open a terminal and navigate to the reform2-lpc-fw folder you've downloaded from the Reform repository.
    • Check lsblk or dmesg -w to find out which drive the LPC shows up as, then edit flash.sh with the correct path to the virtual flash drive (e.g. /dev/sdx).
    • Double-check the path to make sure it is correct, as entering the wrong one could destroy data on your computer!
    • Execute flash.sh as root.
  7. How to flash MNT Reform LPC firmware, Unplug the USB cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the USB cable from the LPC USB port.
  8. How to flash MNT Reform LPC firmware, Set LPCPROG switch to OFF: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to flash MNT Reform LPC firmware, Set LPCPROG switch to OFF: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or your fingernail to set the DIP switch LPCP to OFF, which is the side labeled "1".
  9. How to flash MNT Reform LPC firmware, Press LPCRESET again: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or your finger to press the LPCRST button again.
To reassemble your device, follow steps 1 and 2 in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don't overtighten screws.
Neelfyn
crwdns2935283:005/13/14crwdne2935283:0
972 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,136
