How to fix your leaky faucet
    • Collect rags, a hex key, a flathead screwdriver, a Phillips screwdriver, a crescent wrench, and the correct replacement cartridge.
    • Turn the cold water supply valve under the sink clockwise until it stops.
    • Open the faucet and watch for dripping to see if the leak stops.
    • If water still drips, close the hot water valve as well.
    • Note which handle controls the valve that stopped the leak to identify the faulty side.
    • Close the sink drain or stuff it with rags to keep small parts from falling in.
    • Insert a hex key into the handle set screw and turn it counter-clockwise until the screw comes out.
    • If the handle has a cap, gently pry it off with a flathead screwdriver to reveal the screw.
    • Loosen and remove the internal screw with a Phillips screwdriver to free the handle.
    • Work slowly; extracting the set screw can require patience.
    • Back off any remaining decking hardware to gain clearance around the stem.
    • Place a crescent wrench on the packing nut and turn it counter-clockwise until the nut lifts free.
    • Pull the cartridge straight up and out of the faucet body.
    • Wipe moisture from the faucet cavity and surrounding surfaces with clean rags.
    • Press the replacement cartridge into the housing, aligning any locating tabs.
    • Thread the packing nut by hand, then snug it gently with a crescent wrench without overtightening.
    • Slide the handle onto the stem and tighten the set screw to lock it in place.
    • Open both supply valves fully.
    • Run the faucet for one minute to flush air and debris and confirm that no leaks remain.
With the new cartridge in place and the faucet leak-free, remove the rags from the drain and store your tools. Periodically check the faucet for drips over the next day to ensure the repair is holding.
eCuration
crwdns2935283:005/19/17crwdne2935283:0
449,322 crwdns2915208:0crwdne2915208:0
crwdns2935297:0252crwdne2935297:0
crwdns2942667:0crwdne2942667:0 16
