How to fix the Acer Chromebook 11 C733 Wi-Fi Issue
crwdns2931587:0crwdne2931587:0
    • Make sure your device is powered off
    • Not doing so can result in damage to your device or can result in injury.
  1. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Open up your device: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Open up your device: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close your Chromebook and flip the device over so that the bottom of the case is facing up.
    • Remove all 12 case screws from the bottom of the case.
    • Don't worry about making sure these screws are returned to the same spot because they're all the same size.
  2. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is only held in place with a piece of ESD Tape. Using a set of tweezers, carefully peel away the tape from one end.
    • Once the tape is removed, carefully unplug the battery from the logic board.
  3. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Wi-Fi Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Wi-Fi Card: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the M.2 Screw, and unplug the Wi-Fi Card from the Logic Board.
  4. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Removing and replacing the Spacer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a set of tweezers, carefully remove the rubber spacer from the logic board.
  5. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Placing the Spacer: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Placing the Spacer: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the spacer is removed, place the new spacer in the same area as shown.
To reassemble your device, reconnect the battery and snap the bottom panel back on, and reinsert the case screws.
crwdns2935103:0crwdne2935103:0
Jacob Mehnert
crwdns2935283:010/18/21crwdne2935283:0
39.971 crwdns2915208:0crwdne2915208:0
crwdns2935297:050crwdne2935297:0
iFanatics crwdns2935289:0iFanaticscrwdne2935289:0
Community
crwdns2931471:061crwdne2931471:0
crwdns2935297:0199crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,344
