How to fix a rattling window, E46 M3
crwdns2936621:0crwdne2936621:0
  1. How to fix a rattling window, E46 M3, Identify the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The door card is held securely in place with 5 screws.
    • Keep in mind the door card has up to 3 wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
  2. How to fix a rattling window, E46 M3, Remove screw covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a rattling window, E46 M3, Remove screw covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
    • Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
  3. How to fix a rattling window, E46 M3, Remove bolts: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T20 Torx driver with extension, remove all 5 bolts.
  4. How to fix a rattling window, E46 M3, Remove mirror control: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
  5. How to fix a rattling window, E46 M3, Pop door card clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a rattling window, E46 M3, Pop door card clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
    • After you've released the bottom clips, work your way around.
    • You will need to lift the door card from the door frame in order to fully release it. Be careful!
    • Disconnect the following from the door panel:
    • Unlocking cable
    • Speaker cable(s)
    • Set the door panel aside.
  6. How to fix a rattling window, E46 M3, Door panel removed!: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The door panel is now removed.
    • You will see the airbag module, vapor barrier, and other components.
  7. How to fix a rattling window, E46 M3, Inspect the post: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a rattling window, E46 M3, Inspect the post: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Very gently, peel back the vapor barrier to expose the retaining bolt.
    • Roll the window up.
    • The tar-like substance used to seal the vapor barrier to the door frame WILL release itself to a gentle pull, but it is EXTREMELY sticky, and too much pulling will tear your barrier. Slow and steady is the name of the game!
    • Inspect the bolt. It is probably missing a nut!
  8. How to fix a rattling window, E46 M3, Inspect the other bolt: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While you're in here, inspect and tighten the bottom bolt.
  9. How to fix a rattling window, E46 M3, Find and replace!: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Look in the bottom of your door and locate the nut that fell off that top bolt.
    • Replace the nut onto the upper bolt and tighten.
    • In a pinch, you can use a little bit of that tarry substance to temporarily paste the nut to your fingertip in order to screw it on to the bolt.
    • Ta da! Now closing the door sounds great!
To reassemble your door, follow these instructions in reverse order.
Dom Santangelo
crwdns2935283:009/19/16crwdne2935283:0
655 crwdns2915208:0crwdne2915208:0
What is this bullshit? Ever think people may have both bolts there and tightened down still? Ever think other ifixit $@$* may still need to occur? And this is all you have to offer? Awesome thoroughness…
spamaccount420 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 9,694
