This headset is pretty lightweight and comfortable, sadly, it is easy to damage the cable part between the earcups and the headband. And unfortunately, this cable is no joke, it is a 10 strands cable with insulating paint, and it conveys battery voltage, audio signal, and even button commands from one side of the headset to the other.
In my case, only one important strand was damaged, so instead of replacing the whole cable, I just patched the damaged part.
Earcups can be easily unclipped from the hanger piece holding them
On both sides:
Remove foam protection
Turn the plastic cover 45° to remove it
Unglue right earcup label
Unscrew covers with a Philips #0 head
4 screws by earcups
Left earcup casing contains:
Lithium battery
Button and button connection PCB
Left speaker
Right earcup casing contains:
System on Module with all logic and amplification
Jack connection
Microphone
Right speaker
Cable between left and right is a 5-pairs cable with insulating paint.
Cable pinout is: Play/Pause, Next, Back, Volume +, Volume -, GND, Bat+, NTC, Left speaker +, Left speaker -
Desolder and insulate the V+ battery red cable
This way you will keep things safe from false contacts and destruction
To test if the speakers are working, use a multimeter
Resistance between speaker + and - plots (red and black cables) should be around 62 ohms
If you need to remove the button board from its casing, there is a small clips allowing to free the plastic piece holding it in place
With the multimeter, test the continuity for each line between left and right boards
In my case, the cable is damaged close to the left side
In order to free more of the cable to be able to work on it, remove the glue holding it on the earcup casing
Remove the gold crimp piece with a wire cutter
Need even more cable length? Attack on the headband side
First, remove the copper clip holding the fabric and foam
Scrap the glue to push fabric and foam away
There is a plastic piece holding the cable inside the headband, the only solution I found to get me some more cable length was breaking a part of this plastic piece
Strip the wire around the damaged part of the cable
Separate the damaged strand from the others
Gently scratch the insulating paint from the strand with a scalpel until you see some shiny, fresh copper color
Tin the strand
If need be, add an additional tinned bit of thin cable to help you reconstruct the strand
Test the cable with a multimeter until you manage to reconstruct continuity
Using your favorite option, electrician tape, hot glue or else, make sure the repaired strands never touch each other
Reconstruct the cable as solid as you can, using tape or glue
Don’t forget to resolder the plus side of the battery, without making any contact with anything else
Add some tape or glue to secure the cable:
In the headband, where we broke a bit of plastic
In the earcup, where we removed glue and crimp around the cable
If the skai finish on top of the headband is ragged, you can scrap it away, for instance with a stainless steel sponge
To reassemble your device, follow the unmounting instructions in reverse order.
If you cannot patch your cable, use one of the button commands strands to replace your damaged strand. You would just sacrifice a minor feature for the greater good.
This fix is quite fragile, so next time I have to repair this headset, I will try completely changing the cable for a sturdier 4-pairs Cat-5 cable - I will just disconnect Previous and Next to spare one pair.
