How to fix a broken cable on Marshall Major II Bluetooth
  1. How to fix a broken cable on Marshall Major II Bluetooth, Unclip earcups: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Unclip earcups: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Earcups can be easily unclipped from the hanger piece holding them
  2. How to fix a broken cable on Marshall Major II Bluetooth, Remove earcup covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Remove earcup covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On both sides:
    • Remove foam protection
    • Turn the plastic cover 45° to remove it
  3. How to fix a broken cable on Marshall Major II Bluetooth, Remove right earcup label: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unglue right earcup label
  4. How to fix a broken cable on Marshall Major II Bluetooth, Unscrew earcup covers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew covers with a Philips #0 head
    • 4 screws by earcups
  5. How to fix a broken cable on Marshall Major II Bluetooth, Left earcup casing contents: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Left earcup casing contains:
    • Lithium battery
    • Button and button connection PCB
    • Left speaker
  6. How to fix a broken cable on Marshall Major II Bluetooth, Right earcup casing contents: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Right earcup casing contains:
    • System on Module with all logic and amplification
    • Jack connection
    • Microphone
    • Right speaker
  7. How to fix a broken cable on Marshall Major II Bluetooth, Cable between left and right: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Cable between left and right: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cable between left and right is a 5-pairs cable with insulating paint.
    • Cable pinout is: Play/Pause, Next, Back, Volume +, Volume -, GND, Bat+, NTC, Left speaker +, Left speaker -
  8. How to fix a broken cable on Marshall Major II Bluetooth, Desoldering battery V+: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder and insulate the V+ battery red cable
    • This way you will keep things safe from false contacts and destruction
  9. How to fix a broken cable on Marshall Major II Bluetooth, Testing speaker impedance: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To test if the speakers are working, use a multimeter
    • Resistance between speaker + and - plots (red and black cables) should be around 62 ohms
  10. How to fix a broken cable on Marshall Major II Bluetooth, Ease access to the button board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Ease access to the button board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you need to remove the button board from its casing, there is a small clips allowing to free the plastic piece holding it in place
  11. How to fix a broken cable on Marshall Major II Bluetooth, Test the cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the multimeter, test the continuity for each line between left and right boards
  12. How to fix a broken cable on Marshall Major II Bluetooth, Free some cable length: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Free some cable length: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In my case, the cable is damaged close to the left side
    • In order to free more of the cable to be able to work on it, remove the glue holding it on the earcup casing
    • Remove the gold crimp piece with a wire cutter
  13. How to fix a broken cable on Marshall Major II Bluetooth, Free more cable length: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Free more cable length: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Need even more cable length? Attack on the headband side
    • First, remove the copper clip holding the fabric and foam
    • Scrap the glue to push fabric and foam away
    • There is a plastic piece holding the cable inside the headband, the only solution I found to get me some more cable length was breaking a part of this plastic piece
  14. How to fix a broken cable on Marshall Major II Bluetooth, Strip the wire: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Strip the wire: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Strip the wire around the damaged part of the cable
  15. How to fix a broken cable on Marshall Major II Bluetooth, Scratch insulating paint: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the damaged strand from the others
    • Gently scratch the insulating paint from the strand with a scalpel until you see some shiny, fresh copper color
  16. How to fix a broken cable on Marshall Major II Bluetooth, Repair the damaged strand: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Repair the damaged strand: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tin the strand
    • If need be, add an additional tinned bit of thin cable to help you reconstruct the strand
    • Test the cable with a multimeter until you manage to reconstruct continuity
  17. How to fix a broken cable on Marshall Major II Bluetooth, Insulate strands: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your favorite option, electrician tape, hot glue or else, make sure the repaired strands never touch each other
    • Reconstruct the cable as solid as you can, using tape or glue
  18. How to fix a broken cable on Marshall Major II Bluetooth, Resolder the battery: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Don’t forget to resolder the plus side of the battery, without making any contact with anything else
  19. How to fix a broken cable on Marshall Major II Bluetooth, Secure cable: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Secure cable: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to fix a broken cable on Marshall Major II Bluetooth, Secure cable: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Add some tape or glue to secure the cable:
    • In the headband, where we broke a bit of plastic
    • In the earcup, where we removed glue and crimp around the cable
  20. How to fix a broken cable on Marshall Major II Bluetooth, Bonus: scraping the headband skai: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the skai finish on top of the headband is ragged, you can scrap it away, for instance with a stainless steel sponge
To reassemble your device, follow the unmounting instructions in reverse order.
If you cannot patch your cable, use one of the button commands strands to replace your damaged strand. You would just sacrifice a minor feature for the greater good.
This fix is quite fragile, so next time I have to repair this headset, I will try completely changing the cable for a sturdier 4-pairs Cat-5 cable - I will just disconnect Previous and Next to spare one pair.
Eve Redero
crwdns2935283:002/28/22crwdne2935283:0
2,945 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 173
crwdns2942667:0crwdne2942667:0 4,689
