How to fix a blown heater element in a Toaster
crwdns2936621:0crwdne2936621:0
    • Insert wisdom here.
    Thanks for this video, which helped a lot in repairing my toaster!
    In the end I found that rather than twisting the two broken ends of the element together a neater fix was to simply cut far enough to make enough ‘extra’ element to overlap as far as the holding strip (and a bit beyond). Overlap by sliding one end in the opposite direction to the other under the nearest existing vertical strip (the strips that are there to keep the element in place.) This was enough to keep them in contact in my toaster without creating a ‘knot’, and is almost an invisible fix.
    Hope this comment helps someone else. Thanks again for this great site.
    M Bird - crwdns2934203:0crwdne2934203:0
    • how to fix a toaster
Not too difficult, you need patience though.
jon
crwdns2935283:005/15/16crwdne2935283:0
2,949 crwdns2915208:0crwdne2915208:0
crwdns2935297:022crwdne2935297:0
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - crwdns2934203:0crwdne2934203:0
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 120
crwdns2942667:0crwdne2942667:0 24,941
