How to fix a blown heater element in a Toaster
crwdns2936621:0crwdne2936621:0
    • Insert wisdom here.
    • how to fix a toaster
Not too difficult, you need patience though.
crwdns2935229:05crwdne2935229:0
jon
crwdns2935283:005/15/16crwdne2935283:0
3.210 crwdns2915208:0crwdne2915208:0
crwdns2935297:022crwdne2935297:0
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - crwdns2934203:0crwdne2934203:0
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 26,769
